Does anyone know a special trick to get the wheel free from hub (F250 SD) ?
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #1
westcliffe01
SE MI
Kubota M4500DT, B200 backhoe
My task list today was to do a brake overhaul on my 2008 F250 SD. Last summer I took my Dodge Ram 1500 to get the brakes rebuilt and by the time it was done it was nearly $800. In addition, the guys "forgot" to rebuild the parking brake, which was the #1 issue I needed dealt with since I was going to a mountainous area and the truck is a stick. Apparently they seldom work on a parking brake and the return springs on both sides broke in less than 5000 miles and I had to pay 2 different places to fix it on top of the original bill.
Anyway, the Ford F250 (2008 model with ~75k miles on it, bought used with 65k miles on) was making some complaining noises this winter on the rare occasion I would drive it. So figuring that I would do the work myself to save the cost, AND know how the work had been done to avoid future issues like I had with the Dodge. I have also found the Ford dealerships massively backlogged on work on the diesels. Last time I had an exhaust thermocouple go out, it was at the dealer for over 3 months with no compensation.
Having done many brake jobs, the first thing I was worried about was getting those huge wheels off the hubs. Fear was well founded as no amount of soaking in kroil, nor pounding on the tire with a sledge hammer made any impression on the rust bond between wheel and hub. So I tried a "radical" option and cracked the wheel nuts loose and backed them off about a full turn. Driving like that, it only took 50 yards to break free the passenger side front. So I re-tightened the nuts on that side. Long story short, I drove some back roads slow for miles and miles and finally drove it round in a right circle in a big vacant parking lot, but absolutely could not make an impression on the drivers side front wheel.
So do any of you fellas with experience in American iron have any tips for a greenhorn like me how one might get this wheel free from its grip on the hub ? I did try heat from a blowtorch until I got smoke coming off the studs then later added more kroil. But no cigar...
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #2
Wow the loose lug nuts usually do the trick when all else fails for me. Did you try some quick stops too?
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #3
Don't know about your ford.. I jacked my Dodge up, got under the truck and used a sledge hammer on the back side to free them from the hub
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #4
With the wheel jacked up and lug nuts backed off, hold a wood block (I like to use a piece of 4x4 about a foot long) against the rim and hit it with a sledge hammer. After every 2 or 3 licks, rotate the wheel to a different position and repeat.
Quick stop is relative. I'm losing brake fluid somewhere and don't know where yet, since I can't get the dang wheels off... Anyhow, there is now air in the system and I can't bleed it, so the stopping capability is highly marginal.
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #6
I was going to suggest what you already did! :eek: Maybe some direct blows to the wheel via a heavy hammer on a crowbar or something like it that won't damage the bead. I usually use "anti seize" to "paint" the mating surface of the wheel/hub and always use it on the wheel studs and the surface where the pads contact the "sliding" area of the caliper. (that is when you get that sucker off)
Must have tried that for about 2 hours (with a few pauses).
Same trick made no impression on passenger side either, yet that side broke free after just a short drive with the lug nuts cracked free. So I can't imagine what it will take to budge the drivers side.
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #8
P B blaster let on for a day then go out and run a course at some empty department store parking lot. Take some sharp turns in forward and reverse. If that does not work get a bigger hammer and a larger friend. Do not forget the wood-stack a couple pieces on top of each other. Works with tractors too.
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #9
Prop the woodblock in place on the rim and devise an arrangement that lets you use an 8 foot 4x4 as a battering ram. The added weight will deliver a better blow than what you can do out of position with a hammer.
larry
   / Does anyone know a special trick to get the wheel free from hub (F250 SD) ? #10
I can't believe deriving it didn't work. Aside from driving in a circle, did you try some evasive maneuvers?
Might be time to cash in on a $29.99 oil change w/tire rotation special??
Electric Forklift Pallet (A50322)
Electric Forklift...
Diamond (A53117)
Diamond (A53117)
2013 Nissan Rogue AWD SUV (A51694)
2013 Nissan Rogue...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
