Car Hauler or Equipment Trailer -- What is the difference please?
   / Car Hauler or Equipment Trailer -- What is the difference please? #31
My 16' 7,000 flat with brakes on both axles.
   / Car Hauler or Equipment Trailer -- What is the difference please? #32
Here is a simple solution for loading stabilizers I added to my 12k trailer. Had these on the trailer for about 8 years now and this works well for loading my 8000 lb backhoe
I used 2" box tubing with 1 1/2" that slides inside of it with pins to hold them in place.
   / Car Hauler or Equipment Trailer -- What is the difference please? #33
all great points….learned a lot. I have a kubota grandL 3940. looking at buying a 16' with 2' ramp. I am wondering what kind of chains? how long? binders? how many? ratchets? etc. any thoughts?
thanks
   / Car Hauler or Equipment Trailer -- What is the difference please? #34
How about a dump trailer?
   / Car Hauler or Equipment Trailer -- What is the difference please? #35
thanks
If I did not have anything to secure a tractor I would probably buy 4 ratchet straps with the chain ends, 1 for each corner of the tractor. If you have a loader it if supposed to be tied down and anything on the 3PH needs to be tied down.
Here is and example of the strap like I was talking about. I am not sure if the chain on these is long enough to use to tie your tractor down.
2" Chain Extension Ratchet Straps | 2" Chain Lead Tie Down Straps
You don't ever want to have a strap going over a sharp edge because it will wear through so the chain end makes things nice.
If you start a new thread you will probably get more replies.
   / Car Hauler or Equipment Trailer -- What is the difference please? #36
Great advice. I had already ordered 2 16' 5/16 chains and 4 ratchet binders. I also have a couple of heavy duty nylon ratchet straps. I should be good, but this site sure helped.
thanks again!
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
Rock wood travel trailer (A51694)
Rock wood travel...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2023 John Deere 6130M MFWD Tractor (A53342)
2023 John Deere...
