Car Hauler or Equipment Trailer -- What is the difference please?
   / Car Hauler or Equipment Trailer -- What is the difference please? #31
My 16' 7,000 flat with brakes on both axles.
   / Car Hauler or Equipment Trailer -- What is the difference please? #32
Here is a simple solution for loading stabilizers I added to my 12k trailer. Had these on the trailer for about 8 years now and this works well for loading my 8000 lb backhoe
I used 2" box tubing with 1 1/2" that slides inside of it with pins to hold them in place.
   / Car Hauler or Equipment Trailer -- What is the difference please? #33
all great points….learned a lot. I have a kubota grandL 3940. looking at buying a 16' with 2' ramp. I am wondering what kind of chains? how long? binders? how many? ratchets? etc. any thoughts?
thanks
   / Car Hauler or Equipment Trailer -- What is the difference please? #34
How about a dump trailer?
   / Car Hauler or Equipment Trailer -- What is the difference please? #35
thanks
If I did not have anything to secure a tractor I would probably buy 4 ratchet straps with the chain ends, 1 for each corner of the tractor. If you have a loader it if supposed to be tied down and anything on the 3PH needs to be tied down.
Here is and example of the strap like I was talking about. I am not sure if the chain on these is long enough to use to tie your tractor down.
2" Chain Extension Ratchet Straps | 2" Chain Lead Tie Down Straps
You don't ever want to have a strap going over a sharp edge because it will wear through so the chain end makes things nice.
If you start a new thread you will probably get more replies.
   / Car Hauler or Equipment Trailer -- What is the difference please? #36
Great advice. I had already ordered 2 16' 5/16 chains and 4 ratchet binders. I also have a couple of heavy duty nylon ratchet straps. I should be good, but this site sure helped.
thanks again!
2023 JOHN DEERE 2032R LOT IDENTIFIER 151 (A53084)
2023 JOHN DEERE...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
40' shipping container (A52377)
40' shipping...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
