Synthetic oil myth or fact?
   / Synthetic oil myth or fact? #21
We've had a few customers that have switched to synthetic (from us) from our conventional oil and have started burning oil for 3-4 oil changes which seems to subside after that timeframe, no apparent leaks.
   / Synthetic oil myth or fact? #23
diesel lover- (original poster)- It seems this has gotten a bit off topic. Obviously there are applications for synthetic oils for many different types of systems and each have their own unique applications: 2-stroke engines (mix), hydraulic systems, gearboxes, Jet engines and gas and diesel engines, etc. You didn't say if your truck in question was gas or diesel, but assuming by your online name it would be the latter. In any case, hope you got your answer. Here is a link with some good information about synthetic oils, and help clear up "myth vs. fact"
http://www.tractorbynet.com/forums/oil-fuel-lubricants/256235-synthetic-oil-synthetic-not.html
   / Synthetic oil myth or fact? #24
In my 1500 Gold Wing I used to run the standard oil and had no problems. I changed to there HP4 synthetic/mineral blend because I liked the idea of more miles between oil changes and I could tell a slight difference in how it shifted. There was never a problem with the shifting but it just got slightly smoother.
Also I am confused when it is said to not mix synthetic with standard oil. Some of these oils are blends as are other brands.
http://motorcycle.honda.ca/Content/...nericContent_FFH/oils-and-applications-en.pdf
   / Synthetic oil myth or fact? #25
I don't think it's quite as bad as "Letting the Beams Cross", in Ghostbusters.... ;)
If you have a specific high-end additive pack in an oil, you may end up watering it down with another lower cost brand.
At factory OCI intervals, I don't consider a bit of mixing to be the end of the world. If you are pushing out OCI (as already stated, best done with Used Oil Analysis), then yes, I'd stick with top ups with the same brand of synthetic oil.
In terms of engine damage/wear, most of it is coming from lack of oil, or driving way past the OCI.
Rgds, D.
   / Synthetic oil myth or fact? #26
You have a leaking seal. You may never be able to pinpoint why it started leaking. If it were me, I'd change the seal and do whatever I could to buy the most affordable oil, regardless of synthetic or dino, and a quality brand filter and change both at reasonable mileage intervals. One can speculate until the end of time. Seals wear, mileage adds up, colder climates wreak more harsh results. YMMV, but it's still your issue to solve in the end, regardless of why.
   / Synthetic oil myth or fact? #27
I'm a "what ever is on sale" type of oil guy. My Kubota was the first to get synthetic for two reasons. First is can get below -30F in the winters and secondly my tractor may not get used for weeks so any oil that was clinging to things like the cylinder walls has now made it's way back to the oil pan which increases the chance of wear. I now have a Toyota that uses 0w20 that only seams to come in synthetic. But they also recommend 10k miles between oil changes under normal use. For the price of the oil vs the mileage difference it actually works out cheaper to use synthetic.
   / Synthetic oil myth or fact? #28
Synthetic is the way to go, all the time, and forever. I bought a GMC Envoy new and it now has over 240,000 miles on it. It does not use any oil between changes and I change it when the oil adviser on board tells me to, or 10,000 miles whichever comes first.
I would not use anything else in my vehicles, including mowers and boats
   / Synthetic oil myth or fact? #29
The same results happen with mineral oil.
I have a van with 235,000 that doesn't burn oil, or have any blow by, and it has never seen synthetic oil.
Plus, I have always used Fram oil filters in it, which everyone says are junk. :thumbsup:
Every vehicle I have ever owned, has gone very high in mileage, with no oil related issues, using mineral oil.
All name brand oils are very good quality today.
Its a 97 1/2 ton with a 4.2 v6. Perfect truck for me. Good Fuel economy. I had been convinced to change to a synthetic due to this winter being cold. It got down to -14 degs F. I didn't want to go full synthetic so I went to a blend. Truck started every time and I used my block heater as much as I could and as it was needed below 5degs F. I have a freeze Plug block heater and always let my engine warm up before driving. Changed to a blend right before winter and when winter was mostly over I went back to conventional.
I added half a quart of lucas and it seems to be helping. I use lucas when needed but I normally use 1/2 a quart to 5.5 quarts engine oil. No need to use more than needed. I can say I may try synthetic in a vehicle that has less miles in it or a vehicle that had synthetic before,
Informational Lot - Shipping (A53473)
Informational Lot...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
1 pallet of Brake Chambers (A53117)
1 pallet of Brake...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
