puckgrinder85
Platinum Member
We've had a few customers that have switched to synthetic (from us) from our conventional oil and have started burning oil for 3-4 oil changes which seems to subside after that timeframe, no apparent leaks.
Beanz-oil, smells like race track."I do enjoy the smell of two stoke Klotz or Castrol racing castor.....
In my 1500 Gold Wing I used to run the standard oil and had no problems. I changed to there HP4 synthetic/mineral blend because I liked the idea of more miles between oil changes and I could tell a slight difference in how it shifted. There was never a problem with the shifting but it just got slightly smoother.
Also I am confused when it is said to not mix synthetic with standard oil. Some of these oils are blends as are other brands.
http://motorcycle.honda.ca/Content/...nericContent_FFH/oils-and-applications-en.pdf
Synthetic is the way to go, all the time, and forever. I bought a GMC Envoy new and it now has over 240,000 miles on it. It does not use any oil between changes and I change it when the oil adviser on board tells me to, or 10,000 miles whichever comes first.
I would not use anything else in my vehicles, including mowers and boats
Its a 97 1/2 ton with a 4.2 v6. Perfect truck for me. Good Fuel economy. I had been convinced to change to a synthetic due to this winter being cold. It got down to -14 degs F. I didn't want to go full synthetic so I went to a blend. Truck started every time and I used my block heater as much as I could and as it was needed below 5degs F. I have a freeze Plug block heater and always let my engine warm up before driving. Changed to a blend right before winter and when winter was mostly over I went back to conventional.diesel lover- (original poster)- It seems this has gotten a bit off topic. Obviously there are applications for synthetic oils for many different types of systems and each have their own unique applications: 2-stroke engines (mix), hydraulic systems, gearboxes, Jet engines and gas and diesel engines, etc. You didn't say if your truck in question was gas or diesel, but assuming by your online name it would be the latter. In any case, hope you got your answer. Here is a link with some good information about synthetic oils, and help clear up "myth vs. fact"
http://www.tractorbynet.com/forums/oil-fuel-lubricants/256235-synthetic-oil-synthetic-not.html
