My War on Poison Ivy
   / My War on Poison Ivy #61
I might save some poisin for this winter. I will let it get went and then throw it in the stove and shut the draft off so it will really smoke.
   / My War on Poison Ivy #62
In the pic, the plant on the right is salal, a harmless plant, the center one may be poison oak, I don't know the one on the left.
   / My War on Poison Ivy #63
Are you talking about this one?
I can't remember where I got it, I think off of either Ohio, Mich or PA (DNR) Department of Nat resources.
Yes those are all bad for ya plants. there are several varieties of Sumac, often called different names, I can post pics of Stag-horn Sumac as I have that on my property. The poison Sumac is more rare up here and I got it pretty bad ONCE when I was a kid as it makes a really good playground when it gets big. I also got Poison Oak ONCE when I pulled up some dead leaves off in fall and made a fire with it in almost dark while fishing in late fall. Ya we all ended up with it but I got it worse (still not a real bad reaction considering what I did with it.) I live around the P.I all day even here in town but the Oak is less predominate & even less of the P Sumac. The Staghorn is common around here with smaller patches of Poison variety mixed in. Bare in mind that local & regional variations are common of most species that look a bit different but are from same base plants.
Mark
   / My War on Poison Ivy #64
We have a saying around these parts.... Leaves of 3 let it be
   / My War on Poison Ivy #65
Never got a rash from poison ivy in my life...until...it got in my tear ducts about 8 years ago. That is the most miserable I've ever been in my life....EVER. I don't know if I would get a skin rash from it today, but there is no way in H - E - double hockey sticks I intend to find out.
I was thinking about getting disposable pipettes, loading them with Glyphosate and letting the evil vine drink it in all year long, probably reload them on a monthly basis? I have arm size vines and want them dead, dead, dead!
   / My War on Poison Ivy #66
Glyphosate enters the plant thru the leaves, then is translocated to the roots, where it kills the plant. Putting it into the soil is a waste of time, herbicide and money.
Poison oak & ivy have waxy leaves which reduces the herbicide uptake. A solution might be to use more surfactant than you normally would. I have found that to be effective on other plants.
Also, you should probably spray in the fall before leafdrop. At that time the plant is taking nutrients and herbicide from leaves to roots. Works well with other deciduous plants.
   / My War on Poison Ivy #67
Guess I wasn't real clear on my intent. I plan to drill into the vine using a 12" long drill bit near the base like the OP, then place the Glyphosate filled pipettes in the hole rather than feeding the herbicide with a syringe (unlike the OP). When empty, I'll replace the old empty pipette with a new filled one while discarding the old one in a plastic bag to contain any oils it may have on it.
I didn't see how effective the OP found his method to be. That would be interesting as well. EDIT: I see in 2013 the OP "still has the PI market cornered. Guess the drill & feed with syringe didn't work. Hopefully the pipettes will give longer term exposure.
Talked to a guy yesterday that suggested driving copper wire pieces into the base of the vine. I may try both methods and see which is most effective.
   / My War on Poison Ivy #68
Death to all Poison Ivy!
   / My War on Poison Ivy #69
I didn't read the entire thread but if you do have problems with poison Ivy getting on your skin and causing problems. My wife is very sensitive to poison ivy and has had many runins with this terrible stuff. We have found these two products to do an outstanding job in reducing the amount of exposure and itchiness.
She uses this product after gardening to wash away any areas of contact. Poison Ivy Cleanser | Coretex Products, Inc.
Whatever does not get washed away and does appear this product will knock it out and significantly reduce the itching and swelling associated with poison ivy. Product Information - Zanfel Poison Ivy Wash for treating rashes from poison ivy, poison oak, and poison sumac - Zanfel Laboratories
If you shop around on eBay you can find the Zanfel for $10 or $12. It retails in stores for $30-$40 it does pay to shop around. Cortex wipes again on the Internet is about $.50 a packet.
   / My War on Poison Ivy #70
...Whatever does not get washed away and does appear this product will knock it out and significantly reduce the itching and swelling associated with poison ivy. Product Information - Zanfel Poison Ivy Wash for treating rashes from poison ivy, poison oak, and poison sumac - Zanfel Laboratories
There is a product called "Mean Green" which has the same ingredients as Zanfel, but comes in quart size jars. It is sold as a hand scrub, but will do the same as Zanfel. Price per ounce is much better than Zanfel.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
New/Unused Mini Skid Steer Attachment Set A (A57454)
New/Unused Mini...
DEUTZ MARATHON...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
