Mark @ Everlast
Advertiser
How long is the power cord on the PA300 and is it true that I need to supply the plug? If the power cord is not as long as I want it to be would it be easy to wire in a longer power cord or should I use an extension cord?
No it does not come with a plug. Keep in mind this is a dual phase unit, meaning it can work on single phase 240V or 3 phase 240V. 3 phase requires an extra wire which is not used on single phase. The manual shows how to wire properly though. This is standard for units that operate on 1 and 3 phase not to have a plug. Almost all our other units come with a plug except the cheapest mosfet units which I do not promote and any unit capable of 1 and 3 phase.
The wire is about 8-9 ft. If you use an extension cord, make sure it is heavy enough and is at least 8 ga if it runs very far.
