ShieldArc's Amazon killer deal on Everlast???
   / ShieldArc's Amazon killer deal on Everlast??? #211
What gauge welding cable does everyone recommend if I want to make 25' cables up? Thanks
1/0...though #1 might be plenty. What you have is 2/0 I think.
   / ShieldArc's Amazon killer deal on Everlast??? #213
Can you tell me more about the optional tig welding features with this welder?
   / ShieldArc's Amazon killer deal on Everlast??? #215
As a precursor to my comments I will say that even though I have O/A'ed for quite some years my stick welding experience is only 2 years and my scratch TIG only one year. I am looking at a "reaL" TIG machine but that is still in the future. Scratch TIG will work for now.
I have a Brand X inverter stick welder that I like but have had some problems with. It was replaced under warrantee once and I think that it maybe exhibiting some issues again thus I jumped on this deal.
First I will say that I wish I had gone with Everlast instead of Brand X 2 years ago but I got a heck of a deal then as well so I can't complain.
I spent about 3 hours welding with the PA300 today and am very impressed. IMO it clearly is superior overall to Brand X and especially with 6010. With 6010 10P-PLUS I was amazed at the difference in puddle control I had with the PA300. The range of arc force seems to be significantly broader than I have on my other machine. The Arc Force knob is labeled 1-10 but has 12 gradations so it is hard to say what each increment is (0.833/increment) 1, 1.833, 2.667, 3.5, 4.333, etc so I will ignore the 12 increments and just say 1 through 10 using increments of 1. The lower end of the range "1" seems to have more manipulation of the arc than what the other unit has at the "1" setting but are pretty close. The upper limit on the PA300 however seems to me to be a fair amount higher than the upper limit on Brand X. I really felt like I was able to do some things with the puddle that I have not previously been able to do when I was using arc force at 10. Of course with both machines using 10P+ there was spatter as would be expected of 6010. Overall I would give the PA300 a much higher rating on 6010 (at least with 10P+) than the other inverter.
If my description of the arc force range was inadequate maybe the picture will help my description. Higher high end and slightly higher low end.
Switching to 7018: using Esab Acclaim I would say that the PA300 did a very nice job.
My 7018 is normally used out of the ovens but today it was at outside air temp.
I would not say that it stood out as better than the Brand X inverter and if there was any difference between them it was in the noise factor. What I did notice was that with arc force at both 1 and at 10, I had less of a problem with the arc being snuffed out with the Acclaim 7018 than I did with the other inverter brand. When using Excalibur 7018 the other machine has no snuffing problem but it does intermittently with the Acclaim 7018. The PA 300 did not exhibit any issues like that.
Overall I would say the PA300 which does have 50 amps on the other machine is equal to the other machine with 7018 Acclaim and far superior with the 6010 10P+ rods that I was using.
Glad that I jumped on the deal before Amazon raised the price up. I got the Jun 2013 machine vs what many/most of you got with the Oct 2013 machine.
Be careful with the plastic cover on the faceplate. It does not gravity fall down but remains wherever you left it and since I am not used to having a piece sticking up in the air I clipped it several times. I did not do any damage but could have easily broken it off. So watch that as you start to use yours.
I will post a review on Amazon
   / ShieldArc's Amazon killer deal on Everlast??? #216
Speaking of ovens......
What have you guys done?
I am contemplating using an old army type of metal box, and putting a line voltage stat and light bulb in it, but since it has no insulation, that may be operationally expensive.
Also what temp should the low hydrogen rod be maintained at?
   / ShieldArc's Amazon killer deal on Everlast??? #217
Watch Craigslist. I got three of them for $50. Great deal
   / ShieldArc's Amazon killer deal on Everlast??? #219
I watch Craigslist daily and never find much good stuff there
   / ShieldArc's Amazon killer deal on Everlast??? #220
The oven question is often discussed. I think it depends on the weather in your locale. Wet, humid, cool days might require an oven for code work.
With hot, low humidity days like we get in the CA Central Valley I just use those round plastic sealed rod holders that can be found at Harbor Freight for cheap (or elsewhere more expensively).
One thing I tried was to use a large (14") covered electric frying pan and heated the rods at 400° for 3 hours before using them. I couldn't tell the difference that heating made.
His holiness, ShieldArc, likes to tell the story about engineers leaving the lid off a box of 7018 in the rain. He had to dump out the water and just used the rods as they were - soaking wet. But he can tell the story better.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
JOHN DEERE 333G SKID STEER (A52472)
JOHN DEERE 333G...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
Informational Lot - Shipping (A52748)
Informational Lot...
