Rifle targets-need ideas
   / Rifle targets-need ideas
I shoot 8" and 12" targets suspended from chains out to 550yds and I can always hear them "ring" and see them swing.
At a far enough distance it wouldn't be an issue.
Bang---pause---clang
If the distance is not far enough you don't get the pause.
The metal you shoot at also affects the sound as well direction of wind.
   / Rifle targets-need ideas #82
Saw this over the weekend. Looks like a pretty cool setup if you have the $.
Bullseye Camera Systems - The Ultimate Target Camera, Shooting Camera and Long Range Shooting Camera
For target viewing I use either a Leoupold spotting scope or the wireless video camera that I use on my RC aircraft, from boostervision.com they cost a lot less than the one you linked.
I would not suggest using it to view hits on steel unless you put it behind bullet proof glass.
Jean, I will check on the sensor.
   / Rifle targets-need ideas #83
   / Rifle targets-need ideas #85
What about a paddle with 4 sides rotating on a pole? When you hit one, another one rotates up. Paint each paddle a different colour so you can see when it has rotated.
That's one of the most creative ideas I've come across.
Wonderful picture as example as well.
How would you get the paddles to stop at the right spot?
   / Rifle targets-need ideas #87
They won't, they will spin and stop at random places with random colors showing, but what difference would that make? You would still be able to see the change of colors and the motion..
I would prefer shooting at the face of each paddle, avoiding weird angles.
   / Rifle targets-need ideas #89
Ok, rifle target version 2 has a little plastic tab that allows the paddle to spin, but then slows it and stops it in the right place. Kind of like how a hockey card in your bike spokes (for that awesome engine sound when you were a kid) would be placed. :)
   / Rifle targets-need ideas #90
You could also make sure the axle was on a good bearing, and then weight one of the vanes so that is is heavier and will always stop with that vane pointing down.
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
