Thoughts on Stabalizer Links and 3 Points
/ Thoughts on Stabalizer Links and 3 Points #21
Bob,
See your pic attached. This is what I tried to explain in my previous post and I think James indicates the same. Pull the pin on right, Raise the implement and push the arm in the direction of arrow then replace the pin. Do this on each side and you should be good to go.
/ Thoughts on Stabalizer Links and 3 Points #22
Bob,
Yep, that is pretty much it.. he has the pins in the wrong (too long) holes because the joint is scissored together. This allows the implement to flop side to side.
Bob,
I am running R4's 43x16.00-20. My picture (#3) shows the 37" width. I measured from inside lug of the left to inside lug of the right. Tires are 16" wide across the lug edge to lug edge.
Interesting. I went and took the measurements from the same place.
I have 32" lug-to-lug. My total amount of available play for the 3-point with this BB is 6". I think I'm getting a clue. The tractor is too skinny and the BB mounts are too fat. So I went and measured the mounting width for my M/F RC72 Cutter and it's max width is only 25" -- 5" less than the BB and I don't have trouble with it.
Ignore my little friend at 26 1/4!
So the dealer sold me a Woods 6' BB assuring me it was all set for Cat 1. Yet it appears to be spaced for Cat 2? Does Woods just bore a bigger hole and sell fatter pins for Cat 2 customers?
I'm thinking I'll have to shop for a longer Cat 1 pin and a wear washer in order to mount the 3-point arms on the inside.
Thanks again for the info.
Bob
/ Thoughts on Stabalizer Links and 3 Points #24
So that is what they mean by a "tick" mark :laughing:
Well, it all might seem good from your house. . . I am actually quite experienced at adjusting the stabilizer links. The pictures are with the tractor at rest and the BB on the ground. I think I have compounding errors.
Yes, the link mounts are bent. Design issue or user error? Pounding them flat will work until you back up the BB again. The links are compressed as far as the bent mounting ears allow.
The BB mounting widths are too wide for Cat 1 tractors and the pins are too short to mount the arms inboard. The arms are fully splayed when mounting the BB. You will not be able to push them in as suggested in the picture. So it will be my task to research longer Cat 1 pins for use with the BB.
And I've finally found something on the farm whose rear is too skinny. I hadn't really thought about that and its curious to have it pointed out. It's about the first thing on this LS I can't defend, Darn! What's real irritating is that I use the BB for ballast so it spends a lot of time chipping away at those tires.
Thanks, Bob
Hey, James, rainin'? Thick air & noisy around here.
/ Thoughts on Stabalizer Links and 3 Points #27
Extremely dark and threatening here. It is like 9 o'clock, but no rain so far.
/ Thoughts on Stabalizer Links and 3 Points #28
YardBike, I have the the exact same tractor as you, here are some pics of mine with a Cat 1 quick-hitch attached.
Mine is nice and tight and doesn't sway much at all. I think you just need an adjustment. :)
/ Thoughts on Stabalizer Links and 3 Points #29
Thanks, Bob
Well Bob, Since my 37" rear end is bigger than your 32" (Boy, that doesn't sound right) I guess you'll just have to break down and buy a Cat 1 BB that will fit your skinny rear end and ship the one you have up to me. I'll force myself to take it off your hands.
/ Thoughts on Stabalizer Links and 3 Points #30
Thanks, Bob
I think the answer is to get longer pins to mount on the inside. They did that on my snowblower. For a box blade you may want to have a sleeve between the insides of the two gussets to help reduce twisting stress, which will be a lot more than for a snowblower. Here's the photo of my setup:
Edit: ...just rereading post #23 and I see you have already come up with this option.
/ Thoughts on Stabalizer Links and 3 Points #31
Ha! I see you run his big brother. The end-user modification you speak of is in your future, too. Back up the BB a few times and yours will look just like mine. For awhile I was thinking one of my links was defective as it was bent and the other was straight. Now they're both bent to match without any effort on my part. Bob
Wasn't speaking of the bend in the end of the linkage, mine are like that from the factory, no backing up with a blade needed. The bend forces it to buckle in a controlled direction when the link is put in compression. I was referring to the slop in his linkage adjustment. If the OP would straighten out the linkage at the pivot he could get it a bit tighter and reduce a lot of away in the implement. Underdog's pics show what I was trying to convey.
/ Thoughts on Stabalizer Links and 3 Points #32
Something else you could do is just go to TSC and buy some Cat 1 pins with the threads and nuts. Mount them so that the shank stick in between the ears and the pins in towards the center of the BB. Similar to what they do on Cat 1/ Cat 1 limited mounts.
For the record- Standard Cat 1 is 26" spread on the lower links.
These are the std pins I am referring to-
YardBike, I have the the exact same tractor as you, here are some pics of mine with a Cat 1 quick-hitch attached. Mine is nice and tight and doesn't sway much at all. I think you just need an adjustment. :)
Thanks for the pics. Man, that is tidy. So you ever back that thing up? So you got me thinking about how much slop there is supposed to be in those links.
I dropped the BB to pull the tractor in out of the rain. There is only one position on the link where the arm won't clank the PTO shroud or get over into the tire. Here is a pic with full 3-point arm movement each way (nothing mounted).
Note when going towards the tire, the geometry caused by that bent ear adds to a lot of the slop and makes it appear as if the link is out of adjustment -- too long.
Another words, once the 3-point arm is splaying out, the link ear bend causes the link adjustment to look wrong.
Maybe I will take the male section off and try the BFH method of adjustment in the morning. Either way I'm shopping for new Cat 1 pins on the BB.
Bob
Yes, thread Cat 1 studs poking inside the mount would seem ideal.
But the shroud that bolts on and reaches up for the top link does not give a flat mating surface for torquing down the bolt on pins.
Cat 1 spec is 26" spread? Thanks, didn't know that. Oddly, Woods can claim they are in spec -- at the max end of the spec.
Bob
This is very rocky, hill terrain and I've observed some pretty beat up BBs around here. The irony is that I paid a lot of extra dollars to get "the strongest, heaviest 6' BB that fit behind my new tractor!"
Got that in spades.
Bob
/ Thoughts on Stabalizer Links and 3 Points #37
I am going to try one more time.. your last picture shows the link straightned out and then "jacknifed".. but what I am trying to say.. is straighten both out. Then adjust for sway so that the implement does not hit the tire.. when the implement wants to go into the right tire, it is the LEFT stabilizer that prevents it from doing so. IF it is adjusted tightly. And likewise when the implement wants to move to the left it is the RIGHT stabilizer that prevents it from doing so if adjusted tightly, (straightened out not jacknifed).
You are there and I am not, but this is what I think the entire problem is. I could be wrong, I have been before.:)
/ Thoughts on Stabalizer Links and 3 Points #38
Yes. Exactly what I hope to do. I wonder if that big washer has a special name. . .
Thanks, Bob
It looks like you could remove the top link tower and remove metal where it impedes putting Cat 1 pins on the inside. You wouldn't have to remove a lot to allow them to fit flat/flush, and it wouldn't weaken the tower any.
Or....
Go to a JD dealer and tell them you need the draft arm mounting pins for a 647 or 655 tiller. They should be long enough for you to do what you want. They are the same thing as in the pic in the post of your I quoted here. You can see mine lying on top of my tiller. The one near the top link tower is for the top link, and is the same basic design, only in the correct diameter for the top link-
Went down to the dealer and longer pins are no problem. They were right there on the rack along with washers. CNH brought them in from India and I brought them home for $11. Using them with the BB brings the outside spread of the lower arms down to 25 inches. At the tires, I now have a 4 1/2" gap between the arms and the tires.
More importantly, now that the lower arms aren't splayed so much, the angle of attack on the stabilizer links are in the sweet spot. No more slop, no bending over the attachment ears, and only a degree or so of sway and a long way from the tires. Happy camper.
As it is a Kioti dealer, I went and looked under the tail of a DK40. Yes, the tires are smaller. This provides 40 inches of separation from the tire lugs. 8 more inches is a lot!
Now I wonder why my inner ear keeps shouting that my LS feels a little tippy?
Thanks to all the contributors talking my way out of this conundrum.
Bob
/ Thoughts on Stabalizer Links and 3 Points #40
Glad it worked out to your satisfaction.:)
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
