rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,722
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Machine is a JD310SG.
thanks, rScotty
thanks, rScotty
If anything ever goes wrong in any way. You can be liable in a lawsuit. Even if the backup alarm was not directly involved. Disabling the backup alarm displays a wanton disregard for safety in general.
Is you BH being used on your property or off site? On your own property unless you are a farmer/employer you can get by with murder till an incident happens and insurance is involved. If used in construction you would not be allowed on my construction site. The OSHA rules require the horn at the decibels stated (would have to look that up). Noisy, yes. Modifications to alarm systems carry a big fine when discovered as that is considered a willful act and blatant disregard for safety. Plus the liability issue if the equipment is involved in an incident. Your insurance company will be harder on you than the State.
Ron
OK, I fixed it. The horn turns out to be a square plastic trumpet type mounted under the BH swing pivot. Easy to look at and even to touch, but near impossible to unbolt....and the consequences of cutting a wire didn't seem worth risking.
So I took the simple approach and stuffed an old sock in it and held it in with a strip of Gorilla tape across the open end.
Bingo! Problem solved! Total time about 2 minutes and cost near nothing. Probably take less than a minute to reverse it. I thought the sock might muffle or reduce the sound, but to my surprise it completely silenced that annoying and - IMHO - attention-robbing beep.
rScotty
