Odd Question - My freezer is sweating??? WTH?
   / Odd Question - My freezer is sweating??? WTH? #31
It's not important whether the freezer has a heated door, or if the door seal has an issue. There would not be that much moisture condensing on it, unless the humidity is high.
The OP has said the basement is humid. Getting the humidity down to 50% or lower is the only thing I would be concerned about right now.
:banghead: Ughh. You may get the humidity down to where leaking cold air escaping doesn't condense water out of the room air. But your wasting so much energy running a leaking fridge and a dehumidifier, when the problem may just be the fact air can move between the cold inside and the humid outside. Seals.
   / Odd Question - My freezer is sweating??? WTH? #32
There is a product called Concrobium you can buy at Home Depot or Lowes (usually in paint aisles) that is great for neutralizing mold (it encapsulates the mold and spores). It's real safe for humans, pets, and building materials too -- I think it's similar to baking soda. You can even fog it in a room to cover everything (Home Depot rents the foggers).
Be *very* cautious using bleach in any concentration on building materials that contain metal. Bleach, and the salt it leaves behind when it dries, is *extremely* corrosive. It can rust and corrode nails, bolts, fasteners, brackets, wiring, pipes, ductwork, etc.... I have used bleach on bare wood that can be cleaned afterwards, but keep it far away from structural framing containing fasteners/brackets, beams, wiring, HVAC, plumbing, etc -- anything metal and important. Mold control companies don't use bleach for this exact reason, as it can cause more damage over the long term from rusting and corrosion. Sure, it knocks out the mold, but if your nails all rust to oblivion after 10 years, that's not too good for the structural integrity of the home!!
   / Odd Question - My freezer is sweating??? WTH? #33
:mur: You are worried about a freezer door, which is probably doesn't have a thing wrong with it, and will take care of it's self, once the humidity comes down from nearly 80%, while the entire basement is in jeopardy of growing potentially dangerous toxic mold, after being flooded, and not properly dried out.
OK, so the basement is MUCH, MUCH dryer!
Things have dramatically improved. I've got the hose hooked up and the dehumidifier runs constantly. I've got my last two fans running constantly also.
Right now the lowest reading I've seen is 60%. this is Virginia, and it is spring so some humidity is inevitable.
When do I decide it is good enough and only run it on an as needed basis?
Just asking...
David
   / Odd Question - My freezer is sweating??? WTH? #35
Just asking...
David
I turn mine on in the spring with a setting that allows the humidistat to cycle between 40 and 50% RH and leave it on continuously. If yours doesn't have a humidistat that shows the actual setpoint, slowly adjust it lower day by day until the desired conditions are met. The motor that runs continuously is just a couple hundred watt motor to circulate the air. The humidistat cycles the compressor off when setpoint is met.
If you are still seeing moisture accumulating on portions of the reefer....closely inspect the door gasket all the way around the perimeter with the door closed. A leaky gasket will not be sticking securely to the face of the appliance and that will be noticeable. The door gasket is merely a long strip magnet enclosed in the soft pliable rubber seal. The seal must remain pliable for the weak magnet to hold it against the metallic surface.
I'm thinking you solved the majority if not all of your issue with the dehumidifier. Oh yeah, another possible option for high humidity in basement areas is to cut a return air opening in the basement duct and install a grille that can be opened and closed. Probably 6 x 14 or so. Drawing humid basement air from the basement through your a/c coil will slowly assist in moisture removal from that humid space. Close the grille in the winter....
The de-humidifier is the sure fire and best solution though.....
   / Odd Question - My freezer is sweating??? WTH? #36
You may as well set the dehumidifer to a reasonable level and leave it there to turn on automatically as needed. I leave the one in our garage set at 55% if I remember right. (Note, the humidistat on most dehumidifiers is not super accurate, so I calibrated against a handheld hygrometer to know where to set the dial). There is a magic number for humidity, below which mold can't grow. Set it to that, and let it come on as needed. I hear ours cycle on 10-12 times a day for a 5-10 minutes each time.
   / Odd Question - My freezer is sweating??? WTH? #37
Mold is killed by contact with household bleach. But is only effective on non-porous surfaces
If the surface is porous, like wood, or cinder block, bleach is only effective on the surface mold. This is because the VOC's that kill the mold mostly evaporate before they can soak into the pours. What is left after the VOC's evaporate is mostly water. Which can help propagate the next batch of mold, requiring future treatments.
Bleach is also toxic, and smells bad.
It's better to use a product like Moldex. It's very effective, has no offensive odor, and inhibits the return of future mold.
We live in a pretty wet area........I just bleached the eves of our house and the cedar shake siding. We had some little black mold dots appearing under the eves and some shake was starting to turn black. After the treatment......eves are white.....looks like we just painted and the shake looks new. As for humidity......some boat owners use a dryer/dehumidifier product like the one below......I use one in our travel trailer.....works well.....never have a moisture problem with it.
Amazon.com : Davis Instruments Air-Dryr 1000 Dryer : Boating Equipment : Sports & Outdoors
   / Odd Question - My freezer is sweating??? WTH? #38
Bleach is good for killing the black spots but I think it is also a bit corrosive on wood so a good rinse is required. As for travel trailers, my in-laws were snow-birds. They didn't scrimp on their RV's but did scrimp in most other things. Epson salts sewed into cloth bags...apparently the salts soaked up a lot of moisture. When saturated the bags became rock hard...take them outside in the sun and get them back to epson salts with a little dropping/banging and start over. Their trick, not mine.
   / Odd Question - My freezer is sweating??? WTH? #39
Yea.....a good rinse is required for the bleach. Up here......people use bleach for roofs, driveways, fences and houses. Works well but good rinse is required.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
