Kubota 9540 steering drifts
   / Kubota 9540 steering drifts #21
Yep, I only notice it when roading. My tractor runs 22mph so it becomes an issue then.
   / Kubota 9540 steering drifts #22
360 over 4 miles is within tolerance. We've had some that are much worse. Its just part of hydrostatic power steering.
   / Kubota 9540 steering drifts #23
My L5740 was right at 360 degrees per mile and pretty annoying, it is now within specs, some drift but not excessive same with our M8540 and previous L5030.
   / Kubota 9540 steering drifts #24
Yep, the New Holland, David Brown, Deere x744 all do it.
   / Kubota 9540 steering drifts #25
My JD 4255 doesn't drift and it's hydrostatic steering with 10,800 hrs on the tach. I think it poor parts clearances & POOR QUALITY CONTROL.
   / Kubota 9540 steering drifts #26
Nah Jim, I think it's just luck of the draw. Doesn't matter what color the paint is. My JD2210 mowing SCUT drifts worse than my Kubota.
   / Kubota 9540 steering drifts #27
Some tractors have a single double acting steer cylinder. The displacement per unit movement is larger on the head end than on the rod end hence the steering wheel will continually drift as you make small corrections back and forth - it takes more turn to steer right rather than left. Many have balanced steer cylinders to counteract this effect - rods out both cylinder ends. At Gleaner, when people's complaints finally got to us, we went the inexpensive way - 2 single acting cylinders, one for turning left and one for turning right. Same cylinder both sides so equal displacement, problem solved. Not saying this is your problem but it is one thing. But some drift will always occur on a hydrostatic steering system. It's the nature of the beast.
   / Kubota 9540 steering drifts #28
Just lift the front wheels off the ground,
move them left to right by hand,
if there's "play" find out where it is and repair it,
if there's "no" play, then it's "the nature of the beast" syndrome...IMO
   / Kubota 9540 steering drifts #29
I still think "quality control of parts or lack of" not luck of the draw is the problem. I think JD's quality control isn't as good as it was in '91 when my tractor was built.
   / Kubota 9540 steering drifts #30
Yeah I agree. Outsourcing parts is a large contributor to that problem. So given that scenario, luck of the draw will determine the end result. :)
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2017 KENWORTH T370 SERVICE TRUCK (A51406)
2017 KENWORTH T370...
2012 Cub Cadet 17YI2ACP056 Zero Turn 50in Lawnmowe (A53117)
2012 Cub Cadet...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
2014 MACK CHU DAY CAB (A53843)
2014 MACK CHU DAY...
