jcummins
- Joined
- Jan 14, 2007
- Messages
- 1,640
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
I recently installed a grapple using a diverter valve. Yesterday did quite a bit of sawing down dead trees and stacking them. I put an atv winch switch onto the fel handle works fairly well, but I found the grapple would open as I curled up, and close when I curled down. I want the opposite of that, so I can curl up with a load and also tighten the hold as I curl up by off and on with the button.
SO....I switch the lines from the diverter valve going to the grapple, at the outputs on the grapple. Tested, and grapple wouldn't close or open???? Confused by this. Since it didn't work, what did I do wrong and how do I adjust.
