... I am not following what you mean when you say that OD should be another shift mode and power path through the gear sets vs. just lock-up. Can you explain this for me.
... the E4OD will only lock the TC in 3rd and OD...
Just means that they are separate functions vs one & the same. OD is a gear range by itself. Lock-up is just within the TC and 'locks' the outer body(/flywheel/flexplate) to the trans input shaft like a stick-shift's manual clutch would. Computer decides which & when in 'D' or 'OD' but can be over-ridden by operator selecting lower gears on the 'prndl'. btw, TC doesn't slip in 'lock-up' & doesn't generate heat as normal slippage does. I'm sure other guys here know Fords better than I do ...
Got it. Thanks.
Blane
