MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,373
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Many temporary bridges are pushed across by making a front extension that will reach across the opening before the balance point is reached, then the bridge is pushed the rest of the way across and the extension removed. You might be able to use a couple of poles fastened to the trailer.
Watch these videos to see the idea in use.
Acrow bridge build animation - YouTube
Compact 200 Modular Bridge Construction - YouTube
Regak Bridge - YouTube
I was thinking similarly... buy two 40' trailers.
Weld them together end to end end so the bridge is 80' long.
Put an upright in the midde about 8' high.
Run a cable from one end, up over the upright and down to the other end to provide some tension.
Push it across the 28' span. Some greased logs should provide an easy surface to slide it on.
Once its on the other side, remove the cable and uprights.
Cut it in half again.
Then you can either double stack it for a stonger bridge, or double width it for a wider bridge.
Sounds like a fun project. Good luck with whatever you decide to do and post pictures!
