B7800 engine injector setting
   / B7800 engine injector setting #11
Thanks guys.
The reason I asked is that I have the same engine as orezok ... and if it happened on his, it could very well happen on mine ... ;)
Thanks guys.
Just take a 10mm wrench and make sure the jamb nut it tight.
   / B7800 engine injector setting #13
Yes, I found a site that has the full regime for setting up the injector pump. It takes a test stand with specialized equipment that measures the exact output of the pump. ...but the adjustor screw is on the outside of the pump so dirt doesn't matter and it is working just fine with "Farmer Tight" adjustment.
Would I attempt to rebuild the pump, heck no! This is just a simple adjustment for the max flow on the governor.
Call Foley Engine Service www.foleyengine.com
They can help you if you do not have a kubota dealer nearby.
   / B7800 engine injector setting #14
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
26ft T/A Dovetail...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56438)
2016 RAM 5500...
