Small Pond Project.........
   / Small Pond Project.........
Your place is looking great! The pond site looks so much larger than what you first drew on your earliest photos. Thanks for sharing.
Yes it has more than doubled in size, I got some advice from someone that said " make it as big as you can". ....and we did.
I forgot to mention one of the best parts of the pond build. The timber Co. Sold the logs for $13,700. Of course I only got half, but that was a nice bonus.
   / Small Pond Project......... #53
That was a nice bonus! Veneer logs?
   / Small Pond Project......... #54
Thanks Eddie, yes porch is half circle. Let me know when you get close to building it and I will show you my builders secret to matching the roof line perfectly to the porch's half circle........if you are putting on a roof.
This is great. Just want I'm trying to figure out for when I do mine. I have a gable end, so it will just come out of the flat wall of the house. What did your builder use to create his beam? I can see OSB with lumber sandwiched between it. I was thinking of just ripping OSB into 11 inch strips and laminating them together to build a beam, but would prefer to copy a design that works instead of thinking up something new.
Eddie
Eddie
The builder took 1 strip of 12" OSB and bent it around the outside radius of the porch. He then attached several 12" 2x4s running perpendicular to the OSB. After all of the little 2x4s were on, he then bent another piece of OSB on the other side. So its basically a bunch of little 2x4s sandwiched between two pieces of OSB. Make sense?
Once it was built they just hoisted it straight up, put in temporary supports and built the roof to flow with the house. In your case I think you could just extend your gable end on out and have it go into a curve (unless your gable end is two story). You at this point could leave it open underneath the curve and have a round vaulted ceiling.
I chose not to vault the ceiling.
Hit a seam of sand/water perpendicular to the dam going right underneath it. The seam is about 4' thick and we are in the process of removing the sand around the dam and trucking it out. Let the cost over runs begin.
Todd, very impressive projects, both the house and the pond! I just came upon this thread, so started at the beginning with your initial post, asking for advice on a small pond! Interesting to see how it's evolved just since February. :) With so many of us enjoying this thread, you do realize that you must plan on having a big house and pond warming when you're farther along. Especially for your Eastern neighbors.
:drink:
Thank you very much, and if you are ever over here in your neighbor state please pop in for an ice cold adult beverage!
   / Small Pond Project......... #59
That goes for barns too!
What an incredible build. You and jk96 have beautiful homes. Thanks for posting. Will be watching.
   / Small Pond Project......... #60
Great looking house and {soon to be} pond. Can't wait to see the pond finished and you stocking it with fish.
Larro
UNUSED TOPCAT QUICK ATTACH TREE SHEAR (A51248)
UNUSED TOPCAT...
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2025 CFG Industrial SSECAG-Y (A50123)
2025 CFG...
(APPROX 12) 2" X 6" X 41" IRON TUBING (A51247)
(APPROX 12) 2" X...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
