Picked up a nice little welding rod oven on CL
   / Picked up a nice little welding rod oven on CL #11
Interesting that RV refrigerator's use a heating element. What would it be used for, other than maybe in defrost mode?
This will help you understand how an RV refrigerator works. But the basic concept is it has an electric heating element to make the heat when it is not running on propane gas..
Gas Electric Refrigerators
   / Picked up a nice little welding rod oven on CL #12
Our local welding shop sells them for around $110, so a good deal!
   / Picked up a nice little welding rod oven on CL #13
Those little portable 10 lb rod ovens are usually about 75 watts.
Sooooo. 75 watts x 24 hours x30 days = 54000 watt hours = 54 Kilowatt hours x $0.11 per Kilowatt hour (the price around here, your price may vary) = $5.94 per month. x 12 months = $71.28 annually. Nothing to sneeze at, but not quite as bad as $720 per year
Welding | Industrial DryRod Ovens & Furnaces | DryRod II Portable Electrode Ovens, PHOENIX 1205500 | B301834 - GlobalIndustrial.com
Might be less than that if it has a thermostat that cycles on and off.
And it would be less for the ones that have better/more insulation.
You can get a 'kill-a-watt' meter for $30-$25 at Harbor Freight or Ace hardware. The you could know for sure
   / Picked up a nice little welding rod oven on CL #14
I leave my 300-pound oven on 24/7. My shop is on it's own electrical meter, it is very unusual for my power bill to be over $30.00 per month.
Looks like online, the newer version of the Phoenix 10# Rod Oven goes between $210-$260, heck I'm happy.
Holy welding rod Shield Arc:shocked:
   / Picked up a nice little welding rod oven on CL #17
Oh that's nothing. :D
   / Picked up a nice little welding rod oven on CL #18
Yep, they do. They operate different than your typical household refrig. Typically a RV frig can run off propane, 110 volt, or sometimes even 12 volt. Regardless of which of the 3 modes they use a heating element to produce the cooling (oxymoron and contradiction but 100% true). Plug a dinky one in sometime and watch your electric bill soar. They simply consume the electricity and that rod oven will too. Those RV frigs are thermo controlled so they kick on and off but they still consume the electricity.
I may be high on my figure but those welding rod ovens but it will noticeably increase your electric bill any way you slice it.
   / Picked up a nice little welding rod oven on CL #19
I see what you are saying, now. I'm vaguely familiar with the LP gas A/C units that gas companies used to advertise.
But I didn't know that there were electric heating element versions of refrigeration. :thumbsup:
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
