Deckover VS. Carhauler
/ Deckover VS. Carhauler #1
antlers125
Elkton,Md
LS J2023h
Need some sound advice of advantages & disadvantages between a deckover trailer & a standard car hauler trailer.
Thanks
/ Deckover VS. Carhauler #2
dragging stuff out of a pickup truck = deck over = seating-> rolling -> getting up / finding step stool to get up on it
dragging stuff out at knee height = regular trailer = nice easy hiking leg up and walking up onto deck.
i guess it goes a tad further, deck over the wheels, deck between the wheels, along with axle under or below the leaf springs.
the trailer i have = deck between wheels, with axle seating above the leaf springs.
for myself i am not hauling cars, or tractors all over the place. i am hauling everything else, lumber, firewood, dirt, rock, crud to salvage yard, or local waste places, and its nice having that step up on ability.
i have 2x4 sides i have for it. (takes 2 folks to place them on and tie them down) but helps being able not having to lift sides so high.
heavier stuff as in actually hauling tractors, skid steers, cars, trucks.... a deck over would more likely be beneficial. due to wider deck, and not having to deal with wheel wells, ya deck may set higher but...so much more room to work with. and ability to load/unload pallets of what ever easier (assuming you have fork lift or tractor with FEL forks). and more so ability to place pallets were you have correct tongue weight.
higher the deck height from ground = longer ramps, and dealing with longer ramps in either how they fold up, or slide up and under the deck can be a bigger issue, along with some sort of legs or something on rear of trailer, that keeps the rear of trailer from going down. so when ya go to load something heavy (car/truck/tractor) ya don't pick up rear of truck, and having it all take off on you down the hill. ((it is that initial driving up on ramps part that can get rather ugly)) without some sort of rear supports you can put down. sometimes built into the ramps, other times you need to physically drop something down and tighten it up. or even block up rear of trailer with some lumber.
i am not a large fan of tilt bed decks. they have there uses, but not for me.
/ Deckover VS. Carhauler #3
All I can say is that I wish I had bought a deck over. Everything I want to buy now seems too wide to fit between the wheels.
/ Deckover VS. Carhauler #4
I've had both. I will keep my current car hauler. The deck over was too tough to load.
Each need is different though.
Chris
/ Deckover VS. Carhauler #5
Own a car hauler. Want to upgrade to deck over.
Loading. Deck over is easy to load with fork lift.
Strapping. You can tie straps down full length of deck over, car hauler you loose 4' at fenders.
Width. Lots of heavy equipment won't fit between fenders.
/ Deckover VS. Carhauler #6
Not on my car hauler. I have d - rings down both sides every 2 feet, even at the fenders.
Chris
/ Deckover VS. Carhauler #7
I have a 24' car hauler, and there are times I wish I had a deckover. So......my next trailer will be a 'car hauler' with drive over fenders and the deck will be out to the outside of the fenders. This will give me the lower deck height for easier loading, and the width of a 'deckover' trailer.
Top Hat Trailers - Online Catalog
I will get the 14k in order to stay below CDL pulling it with my Ram 2500
/ Deckover VS. Carhauler #8
I have had several trailers but never a deck over but my next one will be a deck over with a tilt bed. would like to look at one made to move buildings and see if I could use it for everything.
/ Deckover VS. Carhauler #9
As others pretty well said...depends on needs and/or future needs.
If you have anything to haul that is wider than the fender wells, deckover is the way to go.
IF you plan on hauling any cars or other things with low ground clearance, car hauler is the way to go as they will bottom out trying to load a higher deck of a deck over
/ Deckover VS. Carhauler #10
I have a car hauler because a deck over would put my tractor too high for comfort. A deck over would be nice for forklift loading / unloading long loads of lumber, pipe, structural steel, and metal roofing, but everything else seems to load fine with what I have. The relatively low height is nice, especially after a long day of work.
If this trailer were to be stolen or totaled I would get another car hauler.
BWSwede
/ Deckover VS. Carhauler #11
Thanks
Have both & both have the uses.
/ Deckover VS. Carhauler #12
Perfect opportunity for some company to make a trailer with adjustable axle/suspension so you can have either a car hauler or deckover trailer as needed.
There is a lot of air bag suspension equipment out there that could do it.
Apply something to a trailer, like was done to this truck:
https://www.youtube.com/watch?v=ugicEN4OAKQ
Bruce
/ Deckover VS. Carhauler #13
I have a car hauler and I like the easy loading of my tractor. I usually back it into a small ditch or some other depression and load and unload my tractor without using the ramps.
I would like to easy loading and solid deck of a deckover for hauling other items.
There is a tilt bed deckover at a trailer sales place I drive by that looks really good but I know if I stop I will just get sticker shock.
Car haulers are cheaper than deckovers.
/ Deckover VS. Carhauler #14
I have and use both. The car hauler is nice for the lower height if you're hand loading, but the real question comes down to what do you plan on doing with the trailer?
For what I haul, the deckover wins, but if you haul something different, maybe the carhauler wins.
/ Deckover VS. Carhauler #15
I have both but the one I really need usually has a load of something on it. The little back yard Barns are easy to move with a deckover. Bought two 24 ft truck boxes and had them brought to me on a larger rollback. My car trailer was made in 82 and I used gas station lifts-back when they had two steel ramps on one post. Ran it that way until I came across some cheap alumnium Diamond plate to cover the middle. You can be trailer poor very quickly.
/ Deckover VS. Carhauler #16
Thanks
Car haulers carry 10-15% of their weight on the truck. Deckovers carry 15-20%. Ask yourself what kind of truck you have and how much weight you want to tow and you may answer your own question.
/ Deckover VS. Carhauler #17
I have both, an old car hauler bumper hitch, and deck over gooseneck.
It used to be difficult to get the tractor on the car hauler since I had about 2" of total space to the fenders. When I got bigger equipment, I bought the deck over gooseneck. Heavy loads tow much better with the gooseneck.
It's also wonderful when I get hay and they set it directly on the trailer without having to load it manually :)
The carhauler doesn't get much use any more. I probably should get rid of it.
/ Deckover VS. Carhauler #20
They both have uses, BUT I prefer not to have to work around fenders that get banged up so easily. That's why my trailer deck is level with the top of the tires and the fenders are only 2 inches above the deck, they are flat and heavy enough to drive on and tie down to but still low enough I can get at pallets or lumber with the forks.
(20) ROLLS OF UNUSED KJ K1230-10 FIELD FENCE (A60432)
(20) ROLLS OF...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
iDrive TDS-2010H...
UNUSED RAYTREE RMBG72-72" HYD ROOT GRAPPLE (A60432)
UNUSED RAYTREE...
UNUSED FUTURE FTH50-(50) SHEETS OF GALVALUME (A60432)
UNUSED FUTURE...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
