Backhoe Ford 1520 4WD and Ford 758A Backhoe
   / Ford 1520 4WD and Ford 758A Backhoe #31
Thank you so much, going to get some measurements on my 1900 and see how they line up.
   / Ford 1520 4WD and Ford 758A Backhoe #32
If I were you I'd get it bought if the price is right. Then worry about attaching it. That thing looks pretty nice and it won't last long on craigslist.
   / Ford 1520 4WD and Ford 758A Backhoe #33
So i checked my Ford 1900 and i don't have any side mounting holes like you do, All i have is four bolt holes on the bottom of the tractor. (not sure what they are for.)
   / Ford 1520 4WD and Ford 758A Backhoe #34
Also as for the hydraulics where would i connect the lines too? I don't have a mid hydraulics ports like you do you yours.
Hydro Block top.jpgHydro Line Front.jpgHydro Line Lower Rear.jpgPower Steering.jpgRear Hydro Ports.jpg
   / Ford 1520 4WD and Ford 758A Backhoe #35
Not sure right now a friend of mine has a 1900 I will look at his and get back to you. It's kind of hard to figure out with just pictures.
   / Ford 1520 4WD and Ford 758A Backhoe #37
yea, so i end up looking at the backhoe today and end up putting a deposit on it and will be picking it up on Monday! I could not pass it up, the backhoe was clean all around and very little rust- new paint job would make it look brand new! Now just to figure where it can attach to my 1900 and get some hoses and quick disconnects.
   / Ford 1520 4WD and Ford 758A Backhoe #38
I just got the backhoe today, and i think i figured out a way to get it to attach by making two brackets and attaching it to the side of the loader mounting bolts using 3 bolts.
   / Ford 1520 4WD and Ford 758A Backhoe #39
Just going over the hydraulics and not sure what to do exactly.
   / Ford 1520 4WD and Ford 758A Backhoe #40
You should be able to get pressure from the hydraulic block under the seat right hand side(I think). Not sure where to install a return yet. I'll keep looking. The best thing to do is install a gauge into a port that is currently plugged off and see what kind of pressure you have. One of those that is sticking out of the rear of the block should work. For the return you can always pipe into your fill port using a tee so you don't have to remove the line to add fluid. It wouldn't be my first choice but it's an option. There has to be some installation instructions out there somewhere...the 757/758 backhoes were an option for your 1900. If you can find a copy it would help a lot even though you have a different model hoe.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
Root Grapple (A50322)
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
