Knocking noise from rearend while in high range of transmission on 2005 kubota l3400
   / Knocking noise from rearend while in high range of transmission on 2005 kubota l3400 #11
Check your front axle thrust bolt. I had a clunk sound coming from my JD and swore it was coming from the rear axle.
   / Knocking noise from rearend while in high range of transmission on 2005 kubota l3400 #12
I looked up the L3400 rear wheel torque, 160 ft-lbs. pounds. My 1/2" drive don't go that high, guess I have to look for a 3/4 drive torque wrench somewhere. I'm almost certain if I call up Union Farm Equipment to come get the tractor, they'll drive it around, and say we didn't here no snapping noise, and say it's find, here's the $200.00 bill, thank you and come again, and that's the problem with a noise that's not constant, only happens once and a while. I think the only way of finding this snapping noise problem is if a mechanic has heard of that kind of sound before, and knows rite where to look. A wise man once said, "If it ain't broke, you're not trying"
   / Knocking noise from rearend while in high range of transmission on 2005 kubota l3400 #13
Never heard of this bolt. I'll have to look in my manual with the lousy pictures and see if I can find that bolt, the only clue I have is, it sounds like it's on the front end.
   / Knocking noise from rearend while in high range of transmission on 2005 kubota l3400 #14
Ever figure out what it was?
   / Knocking noise from rearend while in high range of transmission on 2005 kubota l3400 #15
Only heard it a couple times since, so it's hard to pin point still, someone mentioned it might be a wheel bearing. I had bearings before make part time noises before on cars. I didn't haul any logs out this past weekend, so at this rate, this clicking noise could go on for a couple years. I spent an hour in my manual with the lousy pictures, and couldn't find the thrust bolt on the front end, maybe the L3400 doesn't have one.
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
TANK MANIFOLD (A58214)
