Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,709
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I easily run a 6' with my Ford 3000, about 36 PTO hp. My terrain is varied and I found out that you can have too big a cutter unless you are on pretty level terrain. Neighbor had a 7' years ago and as stated they are very large and heavy and the weight is way back from the lift point so the "ft-lbs" gets into the equation meaning that the front of the tractor can get light without adequate counter weight (4wd and loader helps that). I had an 8' with dual dolly wheels and yes it was shorter.....2ea 4' cutters side by side, but it was wide and even with 2 dolly wheels I had scalping and all. Probably went through 6 or so cutters looking for the right size and as stated, 6' medium duty (get the 65 hp gearbox with med duty) was the best all around and that was my last purchase which I am currently using.
Other thing on the 6' is that it is the same size as my tire width so I know exactly where the mower is when doing a fence row. Some like that others like to have the mower sticking out. On the 8' I had I wound up in the fence more than once trying to guess where the fence was trying to get as close as I could to it. Course I could have come back with a riding mower and done the fence.....but my riding mowers don't have AC...grin.
HTH,
Mark
HTH,
Mark
