Input needed (What to Get) Looking at MX5200 / L4901
   / Input needed (What to Get) Looking at MX5200 / L4901
Have you opened and read the third LINK I provided in post #15?
I have used my Bucket Spade to take out Oaks; generally satisfactory up to 3" diameter, then the roots get too hard, too plaited and too deep. I think softwood Pines would be easier. The spade weighs 100 pounds and it arrives sharp and remains sharp; high quality steel.
The Bucket Spade weights 100 pounds. It is rigidly mounted on HDRB bucket which is 397 pounds, which is mounted on LA805 FEL which weighs 1,279 pounds, so total static weight on the Bucket Spade as I position it to go into the dirt is 1,776 pounds, more or less. Then, you can begin to wiggle the FEL, or push the Bucket Spade into the ground with tire traction. You can understand while I prefer the HDRB Bucket over Kubota's standard bucket for mounting the Bucket Spade rigidly.
Bucket Spade is NOT a Backhoe but it does 50% of what a Backhoe does and may be equal for tree planting-----for $400. I believe in keeping attachments simple, and the Bucket Solutions (brand) Bucket Spade is SIMPLE, SIMPLE, SIMPLE.
(pictures show my prior Kubota B3300SU)
I am a repeat customer for ETA, their Landscape Rake being particularly fine. (I complained about paint being banged up on arrival of my Cultipacker in 2012. My 2013 purchase arrived padded with cardboard with paint intact.)
ETA is growing rapidly at present and I have a nebulous feeling that build may be a bit rushed as ETA expands and trains new personnel.
Those link/pictures are great help. You were using the bucket spade on a 3200 machine which is about the same machine I had (B3300hsd). I have to believe with a larger machine like the MX5200 the bucket spade would have no problem taking out little pines. I assume you can just re-sharpen the blade with a small wheel grinder. I think my problem is solved!
I will have to check out the bucket options as well as figuring out hydraulic connections that I should get.
Do you find that you use your landscape rake a lot?
Thanks again,
Steve
I am pretty convinced on getting the bucket spade, grapple and landscape rake and go for it. After I get done all that I can do, I am going to rent a trackhoe and finish it off. After all this is a semi-retirement project and I don't want to spend the rest of my life taking out trees but I don't need to take them out in a week either.
I'm sure I am going to burn most of the vegetation (except the pine trees) as I can get rid of them.
Thanks for all your help!
   / Input needed (What to Get) Looking at MX5200 / L4901 #23
One last thing, and you can take it for what it may be worth. Get ALL the aux hydraulics that you can. 3 rear remotes and a 3rd function of some kind, either true or diverter type. ;)
Thanks for the info.
   / Input needed (What to Get) Looking at MX5200 / L4901 #25
In my opinion you need EITHER rear remotes or gauge wheels to make full use of a Landscape Rake. Gauge wheels can be a bother when rake is used on an angle; the forward gauge wheel and bracket protrude quite a distance beyond the rake. (Photo #2)
I use my ETA Landscape Rake regularly for trail and farm road maintenance and for smoothing food plots, which some day may be fields. ETA Landscape Rake is sufficiently stout to emulate, to a certain extent, a rear angle blade working sandy Florida soil which has been hit with a Disc Harrow two or three times. (I disc my food plots twice per year, once before Spring planting, once before Fall planting.) I have NOT found a Landscape Rake effective at raking tree debris, a Ratchet Rake consolidates tree debris better.
A Ratchet Rake works reasonably well as a debris rake. However, it cannot be angled, nor does it filter. A Ratchet Rake does rip out brush amazingly well. (Many Ratchet Rake review vids on You Tube.)
From York-Modern, manufacturer of York brand Landscape Rakes:
A Landscape Rake follows to distribute loose material, grade, level and remove oversize stone and debris.
Angle adjustments permit discharging material to either side. (User tip: When angled and using caster wheels best results will be achieved if the wheel closest to the tractor is higher off the ground than the one farthest from the tractor. This allows the end of the rake closest to the tractor to rake heavier than the end farthest from the tractor, creating a better screening action as the material moves across the front of the rake.)
The vibrating action of the Rake Teeth breaks up sod and mulches the soil. (User tip: The faster you can go the better the vibrating action will be.)
Pulverized soil passes between the teeth, while large stones and debris are gathered into a row. This screening action produces an ideal finished surface, ready for seeding or sod.
   / Input needed (What to Get) Looking at MX5200 / L4901 #26
You asked if the Mx5200 would be big enough to take out 3 and 4 inch pine trees.. well I think you could easily take them out with it. As for the DK50 it is an excellent tractor, but I am biased. It is more of a deluxe tractor and has some more features than the Mx at a cheaper price , but if you are comfortable with the Mx and the dealer by all means get the Mx. I also second the other comments about getting hydraulic remotes and a grapple.. I like my EA grapple very well on my smaller Kioti, and I would make short work of a bunch of 3 and 4 inch pine trees.
Jeff, Your help has certainly helped me narrow my search. The pictures are particularly helpful. I think I am going with the EA Rake and make sure I have the correct remotes. I need to do further checking with the dealer(s) to see what I can get as far as remotes.
Thanks again Jeff and if you don't mind I might pick your brain more, soon...
I do like the Kioti a lot, but the closest dealer is about 100 miles from me, so I do have to keep that in mind. Either way I think I couldn't go wrong with either machine. Thanks for the input.
Steve
   / Input needed (What to Get) Looking at MX5200 / L4901 #29
MTNVIEWRANCH, aka Brian, can give you a first or second opinion on remotes. He is our in-house expert and vender.
Brian is a little shy but responds to questions such as:
WHAT REMOTE SETUP DO YOU RECOMMEND FOR A KUBOTA MX5200?
WHY?
CAN I INSTALL THESE REMOTES MYSELF?
MTNVIEWRANCH aka Brian can give you a second opinion on remotes. He is our in-house expert and vender.
I will Jeff, because I am really not very knowledgeable about what I need.
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
7046 (A50322)
7046 (A50322)
