Bought my first 8n
   / Bought my first 8n #11
a bad line drawing.. but here is the idea.
the piece witht he flange is what you see at the back of the tractor with the small stub sticking out. long piece with spline hits back of trans at coupler and rear support near shifter mechanism.. aft of pump.. etc.
Ford 8N PTO Shaft Conversion Assembly (9N700-38)
Yea, I had to convert mine.
I didn't have to split the tractor tho
normally on a conversion you don't have to. They just pull out. Mine wouldn't come out so I had to cut it off behind the hydro pump and split the tractor a couple inches to get the pump to drop down.
   / Bought my first 8n #13
With the add ons you want you should really consider a different series as mentioned but I get where you're coming from. Just be careful those front ends aren't made for loader work.
Best of luck and have fun with your tractor.
Here are some pics
   / Bought my first 8n #15
At least she is a side mount distributor
I do not think I would have patience for a front mount
   / Bought my first 8n #16
the orbital valve replaces the steering box completely.
   / Bought my first 8n #17
not too bad actually. you can pull the dizzy off and work on it in your shop.
add a round coil conversion to a front mount dizzy to loose the junky square coil and ballast resistor and they ain't bad. :)
   / Bought my first 8n #19
if i were you.. and not knowing how to do it piece by piece.. i'd buy a kit.
jackson power steering used to sell a kit with a priority valve and orbital valve to tap off loader hyds.
I will it figure out. Thanks though
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
