locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #171
Liked my first one so much I ordered a second. This one came with a seal kit and said if it starts leaking after a couple of months to replace the seals....
A couple of months.. Makes me wonder about its longevity.
Anyone having any leaks?
   / locknlube cupler for a grease gun #172
Actually yes, mine started leaking after a couple months but for me that was a few dozen tubes of grease. I still plan on buying another. For me even a couple months usage is worth it.
Brian
   / locknlube cupler for a grease gun #173
Brian
You might contact to company and see if they'll send u a seal kit.. Looks simple enough and if they're all being shipped now with one they must be having a lot leak....
   / locknlube cupler for a grease gun #174
I didn't get no stinkin' seal kit.
   / locknlube cupler for a grease gun #175
I purchased mine a couple months ago and did not receive a seal kit either. Also makes me apprehensive about the reliability. I do not use mine often and hope it does not start to leak. This is a great device- if it holds up.
   / locknlube cupler for a grease gun #177
Used mine this weekend. It made greasing my tractor much easier. I didn't have to find the "magic" angle to get the grease to go into the fitting, no mess, no wasted grease...so far so good.
   / locknlube cupler for a grease gun #178
Still a :thumbsup::thumbsup: after using mine for some time now.
   / locknlube cupler for a grease gun #179
I've only used mine for a couple of months, probably front loader twice and backhoe 3 times. It started leaking today on every zerk I tried it on. I clean the zerks before greasing of course. I also tried cleaning the coupler head with solvent and compressed air - - still no good. Took the darn thing off and went back to a regular push-on head and that worked just fine to finish the grease job - no leaks.
I plan on calling them to see what they have to say and will do a follow on post here.
BTW, just a reminder, many regular grease coupling heads are adjustable, so you can loosen the head to make it easier to remove. On two zerks on my SSQC, the coupler is passed through a hole and then maybe goes another 6" to the zerk - i.e. not convenient to push it off to the side for uncoupling. I just wait a second for the grease pressure to drop, then pull it straight off with a bit of wiggling - no prob.
I to like the locknlube, it's for sure is a luxurious (if that word is even applicable to greasing!) way to do a messy job - quick, efficient, and nice while it lasted.
bumper
   / locknlube cupler for a grease gun #180
Lately mine is leaking a bit too. Be interested in what they say.
EZGO GOLF CART (A50323)
EZGO GOLF CART...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
