locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #171
Liked my first one so much I ordered a second. This one came with a seal kit and said if it starts leaking after a couple of months to replace the seals....
A couple of months.. Makes me wonder about its longevity.
Anyone having any leaks?
   / locknlube cupler for a grease gun #172
Actually yes, mine started leaking after a couple months but for me that was a few dozen tubes of grease. I still plan on buying another. For me even a couple months usage is worth it.
Brian
   / locknlube cupler for a grease gun #173
Brian
You might contact to company and see if they'll send u a seal kit.. Looks simple enough and if they're all being shipped now with one they must be having a lot leak....
   / locknlube cupler for a grease gun #174
I didn't get no stinkin' seal kit.
   / locknlube cupler for a grease gun #175
I purchased mine a couple months ago and did not receive a seal kit either. Also makes me apprehensive about the reliability. I do not use mine often and hope it does not start to leak. This is a great device- if it holds up.
   / locknlube cupler for a grease gun #177
Used mine this weekend. It made greasing my tractor much easier. I didn't have to find the "magic" angle to get the grease to go into the fitting, no mess, no wasted grease...so far so good.
   / locknlube cupler for a grease gun #178
Still a :thumbsup::thumbsup: after using mine for some time now.
   / locknlube cupler for a grease gun #179
I've only used mine for a couple of months, probably front loader twice and backhoe 3 times. It started leaking today on every zerk I tried it on. I clean the zerks before greasing of course. I also tried cleaning the coupler head with solvent and compressed air - - still no good. Took the darn thing off and went back to a regular push-on head and that worked just fine to finish the grease job - no leaks.
I plan on calling them to see what they have to say and will do a follow on post here.
BTW, just a reminder, many regular grease coupling heads are adjustable, so you can loosen the head to make it easier to remove. On two zerks on my SSQC, the coupler is passed through a hole and then maybe goes another 6" to the zerk - i.e. not convenient to push it off to the side for uncoupling. I just wait a second for the grease pressure to drop, then pull it straight off with a bit of wiggling - no prob.
I to like the locknlube, it's for sure is a luxurious (if that word is even applicable to greasing!) way to do a messy job - quick, efficient, and nice while it lasted.
bumper
   / locknlube cupler for a grease gun #180
Lately mine is leaking a bit too. Be interested in what they say.
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
6 BENCH GRINDER (A53843)
6 BENCH GRINDER...
