angle grinder question
   / angle grinder question #12
Go to HF, they almost always have a cheap one for about $15 to $20.
heck.. look close enough and they have 9.99 sales every now and then. every time they do i grab one.
can use them as disposables on bad jobs that beat up tools. like if working inthe sand, or loaned out... keep my $$ makita at home.. use the 10$ chicom to cut bolts off a disc or track burried inthe sand. e tc..
   / angle grinder question #13
Oh man I have the new Milwaukee 18v cordless brushless and I'm just lovin' it! ;)
   / angle grinder question #14
Makita 5" 9005. Great grinder for the money.
   / angle grinder question #15
Just about every welder I have talked to says metabo is the best out there. Second is bosch. I have a 4 1/2 ridgid (back when they were made my metabo) and it has been great. I also have a 6" metabo that is very nice but haven't had it long enough to speak personally about longevity. I also have a hf 4 1/2 that I rarely use... just doesn't have the power of my other ones, especially with a cup brush, it heats up very quickly- to the point it is uncomfortable to hold.
   / angle grinder question #16
I have never had much luck with harbor freight electric tools, They just don't have the torque. I use their chainsaw grinder but it is awful weak.
   / angle grinder question #17
+1 for Metabo as the best out there.
   / angle grinder question #18
   / angle grinder question #19
If you get a cheap 4.5" make sure its sufficiently powerful. Some of the real cheapies are only about 350w and will slow down rapidly if you use a metal cutting blade. You need at least 500w.
   / angle grinder question #20
i've experienced no problem with 14" chopsaw, 1/2" hammer drill and non hammer drill, 3/8 non fast huck drill, nor any of it's angle grinders.. in the past did get a disapointing wheel grinder though.. replacement was better though.
i did get a chainsaw sharpener and a dremil like tool that was disapointing and was taken back..
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
J BAR SD 5 5' ROTARY MOWER (A57192)
J BAR SD 5 5'...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
404 (A52706)
404 (A52706)
2005 Kubota ZD21F 60in Zero Turn Commercial Mower (A55851)
2005 Kubota ZD21F...
2015 John Deere Z930M 52in Zero Turn Commercial Mower (A55851)
2015 John Deere...
