Installing 240V Service To Your Shop - Price Breakdowns...
   / Installing 240V Service To Your Shop - Price Breakdowns... #11
Why would you need the 50amp in the shop? Just asking. :)
50 amp is the minimum circuit I'd put in for a welder.
(Many people get bigger equipment later)
I'm running 50, 60, and 70 amp circuits right now. :)
I'd run a 100 amp too if I had a bigger line coming in.
   / Installing 240V Service To Your Shop - Price Breakdowns... #12
Your just addicted to power!
I have to admit 400 amps is nice :)
Ah, I see. You made it sound like I need it. I don't. ;)
   / Installing 240V Service To Your Shop - Price Breakdowns... #14
400 amps would be excellent - then I wouldn't dim the lights in the house :D
Too bad - I'm sure I can think of something for you to buy that needs power :laughing:
   / Installing 240V Service To Your Shop - Price Breakdowns... #15
Your just addicted to power! I have to admit 400 amps is nice :)
it's Overkill for probably 90% of TBN members!
200amp residential with 60amps in a shop would suffice for most!
How often do you run a stick welder or a large mig full out? 60amps
And simultaneously run a large compressor 20-30 amps
And simultaneously run a large plasma 30-50amps?
Not saying some members don't but for the most part 100amp service in a shop will more than cover what you need and then some.
Just saying!
Sent from my iPhone 5s 64Gb using TractorByNet
   / Installing 240V Service To Your Shop - Price Breakdowns... #16
There is probably a balancing point between 60 amps and 400 amps. What is the incremental cost for more amps? Will anyone (not necessarily you) want to run tools like an inexpensive welder and a/c? My $260 arc welder calls for 60 amps of 220v at full power. A/C could suck another 15 amps.
A little overkill at first can prevent a need for upgrade later.
   / Installing 240V Service To Your Shop - Price Breakdowns... #17
<snip>
Three weeks ago I was down in Mississippi running my $260 stick welder, PowerArc 300, probably at about 50 amps on occasion and an a/c probably about 15 amps, and probably about 5 amps of lights and fans. If the extra cost to go from 60 to 100 amps was less than half the cost of initial installation of 60 amps I think it would be well worth it.
If the OP is putting in 50 amp service w/ a 125 amp box for $550 with his own labor I think it would be well worth it to go to 100 or 125 amps. I don't know the cost of #6 wire but if you could go up to #2 for the 50 foot plus run for less than $200 additional I think it would be well worth it. (I don't know if #4 is heavy enough.)
   / Installing 240V Service To Your Shop - Price Breakdowns... #18
Me, I would like 3phase. There is so much quality used machining gear that due to being 3 phase sits on craigslist forever. I know you can get the transformers but it would be nice just to have it.
   / Installing 240V Service To Your Shop - Price Breakdowns... #19
Three weeks ago I was down in Mississippi running my $260 stick welder, PowerArc 300, probably at about 50 amps on occasion and an a/c probably about 15 amps, and probably about 5 amps of lights and fans. If the extra cost to go from 60 to 100 amps was less than half the cost of initial installation of 60 amps I think it would be well worth it. If the OP is putting in 50 amp service w/ a 125 amp box for $550 with his own labor I think it would be well worth it to go to 100 or 125 amps. I don't know the cost of #6 wire but if you could go up to #2 for the 50 foot plus run for less than $200 additional I think it would be well worth it. (I don't know if #4 is heavy enough.)
A good reference
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength
   / Installing 240V Service To Your Shop - Price Breakdowns... #20
Just saying!
100 amp worked fine for me, until I got the plasma.
Plasma 70 amps
Compressor 30 amps
Lights 20 amps
The math gets a little wonky adding those up to 100 :)
And then there is my Airco, 60 amps input works for tig aluminum up to 230 amps, so I'm good until I go over 1/4" aluminum.
Then I have to use the 70 amp circuit - it would take 100 amps if I could find some thing to weld at 470 amps :laughing:
But regardless, my son can't use the plasma when I'm using the Airco - have to plan ahead a little.
FENCE PANELS (A58214)
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
