Question about using a landscape rake
   / Question about using a landscape rake #1
lzicc
Pittsburgh, Pa
Kubota B2650
I have a KK landscape rake and I noticed that you can turn 180 degrees. What would be the purpose of doing that?
   / Question about using a landscape rake #2
I use mine turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #3
There's a nice informative video on YouTube by everythingattatchments about all the uses for a landscape rake.
I like that. I wonder if that would work well on a limestone driveway. When I use it on the driveway the regular way, it picks up the too many stones.
I use mine in turned around for smoothing. This way you don't collect much material. ;)
   / Question about using a landscape rake #5
Going forward with rake in reverse you can shallowly cover seed beds, especially wildlife food plots.
Sometimes a LR works better pushing yard debris into piles when reversed and the tractor is operating in reverse.
   / Question about using a landscape rake #6
I run in reverse when I do not wish to drive over piles. Especially piles that could puncture tires, namely old boards complete with nails poking out.
   / Question about using a landscape rake #7
Yes it will indeed,that's how i smooth mine after boxblading the holes out and then using the rake to crown.
   / Question about using a landscape rake #8
That's how we smooth and level gravel with our ROBB too, run forward with the blade facing backwards, it's like using a spatula to smooth out frosting on a cake.
In fact, I'm looking around on EBay for a new shorter top link to make it tilt forward even more and allow it to smooth more and transport even less stone from one place to another.
   / Question about using a landscape rake #9
Wait a minute. I don't know abut this and from the comments I'd say I'm the last to know.
Can you explain more how this works for dirt of gravel a little larger than you have? Sounds like a great idea.
   / Question about using a landscape rake #10
SIXDOGS: I thought you knew EVERYTHING related to tractors and women.
   / Question about using a landscape rake #11
Sorry, but since I do not have any "dirt of gravel" a little larger than I have, (other wise I would have it):rolleyes: I can not definitively describe how it would work. I imagine the same, it would not collect as much material simply because the tines are leaning in a way to be pulled over the material, not digging in or collecting it. ;)
   / Question about using a landscape rake #12
I never really wanted a LR but after reading these ideas now I do , thanks guys . My wife is going to ban me from looking at this forum if she finds out where I get all the ideas from .
   / Question about using a landscape rake #13
Just because I learned how to get a wife to approve a tractor purchase by pushing some numbers around, we shouldn't draw any conclusions.
I can navigate the finance end of confusion but aside from that I'm as adrift as anyone else.
   / Question about using a landscape rake #14
“There are two theories to arguing with a woman. Neither works.”
― Will Rogers
   / Question about using a landscape rake #15
I meant dirt OR gravel. Sorry.
What has frustrated me about a rake is the clumping of material. Then I have a small pile that is difficult to rake out. I suppose wheels on the back would work but factory wheels for a Woods rake are almost $400 (!) and I haven't made the move to build a set yet.
   / Question about using a landscape rake #16
3pt hitch landscape rake = hand held metal garden rake, but up sized for a tractor.
the springy-ness (if that is a word) of the tines that make up a 3pt hitch landscape rake. allows them normally to be pulled forward, and allow each tine to kinda hip/hop skip across the ground, if it is to hard to dig in. at same time let material (dirt / soil) flow through the tines.
when ya turn the 3pt hitch landscape rack backwards, and drive forward, it is like turn a hand held metal garden rake upside down. to smooth stuff out. the tines are not digging in, but rather sliding across the ground to help smooth / level out the dirt/soil.
adjusting the "top link" of 3pt hitch, can give different angles, much like you might adjust angles when using a hand held rake. to kinda feather out the dirt / rock or what not. TNT(top n tilt) for 3pt hitch really shines in this aspect.
do you have a garden with some various melons (grown in some hills)? break out the 3pt hitch landscape rake, in spring / early summer before the vines start growing out, and drive a few passes around the melons to rip out the weeds. without taking a bunch of dirt and moving it around.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
CATERPILLAR D6K2 LGP CRAWLER DOZER (A60429)
CATERPILLAR D6K2...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A60432)
UNUSED RAYTREE...
2444 (A60432)
2444 (A60432)
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
