l235dt, all fluids changed now clutch pedal won't engage for pto
   / l235dt, all fluids changed now clutch pedal won't engage for pto #21
So I need to pull the clutch and adjust the bolts 11 in the following diagram?
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=393625"/>
Yes, there should be 1 mm or .040" gap between the head of the bolt and the pressure plate while everything is still installed on the flywheel.
Rian
Rian
I'm wondering if the bolts/studs holding the clutch to the flywheel are too tight (I'm thinking I may not trust my torque wrench at that end of the scale) would that stop the pto clutch from working?
   / l235dt, all fluids changed now clutch pedal won't engage for pto #23
No - those don't affect clutch operation, they are just to attach the assembly to the flywheel.
Thinking about how they didn't leave an adjustment window in the housing, I'm hoping there's clearance enough to get a wrench in there with the assembly still bolted on.
Brian may know - may have worked on one like yours.
So with a brand new clutch assembly and a new pressure plate.
What should I look for once I re-split the tractor? The gap in the release bolt/pto plate anything else?
Rian
With the flywheel attached, there was no gap. I adjusted it to be .039".
Would no gap cause the problem? Or do I need to look for something else?
   / l235dt, all fluids changed now clutch pedal won't engage for pto #26
I would look for another problem. An excessive gap would have caused the problem you described. No gap would allow both discs to disengage at the same time, that gap is what creates the feel of the two stages.
I'd look at the splines on the shaft, clean all the rust off with a wire brush and lubricate them, then I'd be wondering if the disc got put in backwards.
Brian
Brian
Splines are clean and lubricated. The disk inside the assembly looks to be in the same orientation as the one in the assembly I removed.
if I put the other pressure plate (outside the assembly) in backwards (I don't think I did) would it cause the problem.
Thanks for your help
   / l235dt, all fluids changed now clutch pedal won't engage for pto #28
No it would cause a drive clutch problem.
There is a noticeable difference between the old clutch and the one I installed as far as the geometry. The release bolt on the old clutch had a huge gap (bad didn't work). The fingers stuck out much farther on the old clutch.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
