LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #151
Does anyone have the (WIX, Fram, etc) cross reference numbers for the following filters? They are for a LS XR4046C with tier 4 engine ISM N844L-F.
Oil: 40283380
Fuel: 40285491
Hydraulic: 40007563
Air Outside: 40007576
Air Inside: 40049446
Thanks for your help
   / LS Tractor Oil, Gas, & Air Filter Information #152
Wix filters on line has a look up and x reference. wixfilters.com, maybe, fmsfilters.com has a link to it also
   / LS Tractor Oil, Gas, & Air Filter Information #153
Thanks but I already tried the WIX website and came up empty.
   / LS Tractor Oil, Gas, & Air Filter Information #154
e: LS Tractor Oil, Gas, & Air Filter Information
Here's the list of filters from post 123 in the LS Tractor filter thread
2014 LS XR4046HC Engine Shibaura (Tier 4): N844L-F
Oil filter NAPA # 1056 / WIX # 51056
Fuel filter NAPA # ----- / WIX # -----
Hydraulic Filter NAPA # 1715 / WIX # 51715
Hydro Trans Filter NAPA # 1553 / WIX # 51553
Inner Air Filter NAPA # 6490 / WIX # 46490
Outer Air Filter NAPA # 6489 / WIX # 46489
   / LS Tractor Oil, Gas, & Air Filter Information #155
Thank you. I obviously need work on my search abilities. I tried searching for this a number of times.
Anyway, your help is greatly appreciated. Time for me to get my parts together for the 250 hour Maintenance.
Take Care.
   / LS Tractor Oil, Gas, & Air Filter Information #156
no problem. Glad to help. I am not sure of what I am doing. I wing it and it usually works out some how. Good luck with the 250 hr.
   / LS Tractor Oil, Gas, & Air Filter Information #157
Following Post 123, there are some corrections. This led me to question the accuracy of the information so I sent a message to WIX to get their input. Here is what I got:
Oil: 40283380 = No Information
Fuel: 40285491 = No Information
Hydraulic: 40007563 = Good LS Tractor part number, No Replacement
Air Outside: 40007576 = WIX 46489
Air Inside: 40049446 = Good LS Tractor part number, No Replacement
Not very reassuring. I think I am going to have to go to the dealer this time around for my filters.
Anyway, Thanks again for your help.
   / LS Tractor Oil, Gas, & Air Filter Information #158
No, Not reassuring at all. Although I doubt that any one would post information here unless they felt it was accurate. Perhaps the poster may have more info where he got the information, and a comment from him would be helpful to owners of the XR4046. I would try a PM to him if nothing pops up on here. I didn't find any thing on the Wix site either. Did you try NAPA.? I guess it being a new model info is slow to get out. Is the engine also new?
   / LS Tractor Oil, Gas, & Air Filter Information #159
The numbers posted previously (40283380 & 40283326) are the correct LS part numbers for the XR3037 &4046. The aftermarket may not have caught up yet since they are fairly new models. The other numbers posted by nvmyhd are good cross numbers and are the same for many other models of LS. Not sure if the the oil filter number he listed is correct or verified. I had a different fuel filter # than Thirsty listed.
   / LS Tractor Oil, Gas, & Air Filter Information #160
I received the p/n from my dealer, they are also a Napa distributor.
I did have to make a correction on my original post as I was trying to use the format that was previously used and I'd did not correct everything.
I have used the NAPA oil filter at 35 hours and it is a different filter, the body is shorter.
2005 MACK CXN613C FLATTOP SLEEPER (A55745)
2005 MACK CXN613C...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
200387 (A51247)
200387 (A51247)
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A57024)
2006 Magnolia Dry...
