New model Kubota MX5800
   / New model Kubota MX5800 #2
those are some nice looking kubota tractors.i noticed they added some hp as well.
   / New model Kubota MX5800 #3
Does it replace the MX5200 or is another model with more hp?
   / New model Kubota MX5800 #4
It looks to be an addition to the MX4800 & 5200. It is only available in HST and 4WD from what I could tell and all specs are about the same other than HP.
Still, a pretty nice machine overall. :cool:
   / New model Kubota MX5800 #5
i bet the 5800 replaced the 5740 like the 5200 rep[laced the 5100.
   / New model Kubota MX5800 #7
no the 6060 replaced the 6040.
   / New model Kubota MX5800 #8
Just saw on the Kubota site they have released a new M model, an MX5800, 61.4 hp with HST. Tractors - MX4800-MX5200 Series | Kubota Tractor Corporation
Looks real promising with the higher hp and still with the HST.
I was looking at getting a MX5100 and doing the same. What makes this machine what it is, is a simple turbo swap. Nothing more to it. They use the same engine in their 48-62HP tractors changing nothing but the turbo and the settings for fuel delivery. You'll see this engine in the grand Ls in that HP range. Check out the parts diagrams, they are all the same except the turbo (most likely just the waste gate / blow off)
   / New model Kubota MX5800 #10
All these new models are tier 4 final compliant so have DPF and a nice hefty price increase. I have the MX5100 and love it. As noted above the new models are all on this same chassis, just more HP. helps the salesforce to justify the price increase.
   / New model Kubota MX5800 #12
Are the injectors and cam shaft the same between them. I could see the majority of the engine components being shared as that is very common, but turbo, injectors, cam are different with the hp change a lot of times.
   / New model Kubota MX5800 #13
Only checked turbo'd models, they had all of the same components except turbo assembly. Not sure if the non-turbo motor has different internals, probably the same due to lower cost of MFG all of the same parts.
   / New model Kubota MX5800 #14
That would make it easy to jump up a model with a easy turbo swap.
   / New model Kubota MX5800 #16
It's nice to know my motor in the MX5100 is capable of 61.4 hp, but is "de-rated" to 52 hp. To me, that means it's stout enough to handle the higher power. It should last a very long time!
HP
   / New model Kubota MX5800 #17
HP
I was thinking the same thing!
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
