Check the coupling between the engine and pump. It's a common problem.
Thanks Dave. The "love-joy" is broken,piece that connects the motor shaft to the hydro box. TSC is going to try to order the part for me.If this is how you shoot in the Dark, you must rely be good in the Daylight.![]()
No rubber/neoprene shock absorber between the two halves of the lovejoy? It would be round--with three wedge-shaped "ears" that fit between the metal parts that are sheared off.
the one TSC thought would fit did not have any rubber either. Just the metal with 2 different shaft sizes.
