TSC 22 ton log splitter, problem
   / TSC 22 ton log splitter, problem
Thanks Dave. The "love-joy" is broken,piece that connects the motor shaft to the hydro box. TSC is going to try to order the part for me.If this is how you shoot in the Dark, you must rely be good in the Daylight. :)
   / TSC 22 ton log splitter, problem #12
Check the coupling between the engine and pump. It's a common problem.
You'll have to thank triptester for the diagnosis. I just helped you find the right spot to look in for his excellent call. :D
Glad you are on your way to the fix. Winter is coming.
   / TSC 22 ton log splitter, problem #15
No rubber/neoprene shock absorber between the two halves of the lovejoy? It would be round--with three wedge-shaped "ears" that fit between the metal parts that are sheared off.
I will have to look on the ground for that. It would of had to break in 2 pieces because of the shaft. Maybe that is why it broke. TSC has to order the part as the manufacture has changed it.
   / TSC 22 ton log splitter, problem #17
Lovejoy couplings are normally stock off the shelf items. The two haves one to match each shaft diameter and the rubber spider that goes between them. They come in different sizes I prefer the bigger size, I believe they are the L-100 series. Just make sure they fit inside the engine to pump adapter.
the one TSC thought would fit did not have any rubber either. Just the metal with 2 different shaft sizes.
   / TSC 22 ton log splitter, problem #19
Well ... That don't seem right. That's no different functionally than a piece of round stock with a different size hole at each end and two set screws. I don't have any log splitter experience so I just don't know.
   / TSC 22 ton log splitter, problem #20
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Bell B30E (A50123)
Bell B30E (A50123)
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
ATTENTION! PLEASE READ (A53316)
ATTENTION! PLEASE...
