Stripped Stud and Stud Extractors
   / Stripped Stud and Stud Extractors #1
llbaker2
Vichy
2012 Kubota L3400
I'm interested in a bolt extractor set. Problem is I'm confused by sizing of extractors. Are given extractor sizes in reference to the hex size (flat to flat of bolt head - dimension H in diagram below) or the normal dimension of the bolt shaft (dimension D in diagram below)? I assume its in reference to the hex size (dimension H) but I'm not sure. I am trying to remove a M16 x 1.5 wheel stud not a bolt (doesn't have a hexagon head). I need a stud or bolt extractor that will fit the shaft of the stud which has a normal dimension of 16 mm (dimension D in diagram below). A 16 mm bolt would normally have a bolt head that fit a 24 mm socket/wrench (dimension H). When trying to remove the lug nut from the stud I stripped the threads from the shaft of the stud. One would normally put two nuts on the stud and tighten one against the other then turn with a 24 mm socket/wrench to remove the stud but I cant do that because I stripped the threads. I could try to clean up the threads and try to get two nuts onto the stud but doubt the damaged threads would stand up to the torque that would be required to remove the stud. I hope the bolt extractor will have enough bite to take the required torque to break the stud loose so I can replace it with a new one. My question is what size extractor would I need to fit the shaft (16 mm normal dimension - dimension H below) of the stud for removal? Might just weld a nut to the stud but would be nice to have a set of extractors for future.
   / Stripped Stud and Stud Extractors #2
If the treads are ruined already, and you have plenty of stud sticking out to get ahold of. It maybe easiest to just use a pipe wrench and spin it out.
Or weld a nut to the stud and spin it out .
Yea, I been practicing a little. I'm a total welding rookie. Just got my first machine (MIG). I have no confidence in my welding. Been running some practice beads and tried welding a nut to a 1/2" bolt for practice before doing it for real. Will most likely try that first but think I would like to have a set of extractors. I now have an excuse to get them. Would like to be sure I get something that will fit the stud if I decide to go for it. Had one heck of a time getting wheel bolts/studs broke loose. Wound up spraying them with PB Blaster, let them soak overnight and then hammered away on them with 1/2" impact for quite some time before they finally broke loose. Not sure a pipe wrench would cut it - to tight (at least my old worn out hand-me-down wrenches). Think the heat from welding a nut onto stud might help.
   / Stripped Stud and Stud Extractors #4
This Craftsman bolt extractor set gives the bolt sizes it will work on. (click the view full description)
Sears.com
Thanks for response Vince but I think you miss my point. When it says in the description for example "#3 Bolt-Out fits 11mm and 7/16 in. size fastener" doesn't that mean it fits an 11mm and 7/16" bolt (with hex head). What if its a stud with no bolt head, just a threaded shaft. The head on a 7/16" bolt is way bigger than the shaft. A 5/8" wench (hex size) is standard for use on a 7/16" bolt (see bolt chart at https://www.boltdepot.com/fastener-information/Bolts/US-Bolt-Head-Size.aspx). For example according to this chart I'm guessing you would use a 1/4" extractor to remove a 7/16 stud because I think a 1/4" bolt has a 7/16" hexagon head.
Oh and by the way Who's on first?
   / Stripped Stud and Stud Extractors #6
No. They are saying that is the size of bolt/stud this kit will fit with no head. Shaft only
You hammer the extractor onto the stud. The extractor bites onto the stud shaft and you screw the stud out.
   / Stripped Stud and Stud Extractors #7
Usually there is no bolt head at all. That's why you need the extractor. Use the nominal bolt size. It is common to find the same size bolts with different size heads, especially when you get to 1/2 inch and above. But a 1/2 inch bolt is always a 1/2 inch bolt, even if one has a 3/4 head and another has a 13/16 head.
Bruce
   / Stripped Stud and Stud Extractors #8
You said lug nuts so I am wondering if the stud is not the normal pressed in type with a round head on the inside ? if it is you just drive it out with a large hammer and replace it the same way with a new one = better check the back side for a round head if so just drive it out it is not threaded into the hub .
   / Stripped Stud and Stud Extractors #9
It could be either type. Threaded or pressed.
He does need to check that.
I know my tractor has lug nuts on the outer side, and the stud treads into the hub on the inside
Bruce
Most descriptions I've read reference use on rounded off nuts and bolts and/or studs. Big difference between diameters of the two. When the corners of a hex head get rounded off a wrench will just slip off thus the use of an extractor. Don't think you can say "usually there is no head" because I think the socket type extractors I'm talking about are frequently use on rounded off hex heads. While it may be common for a given bolt to have multiple hex sizes there is a "standard" size associated with bolts (see link to chart in previous post). There are exceptions to just about everything. While its true a 1/2 inch bolt is a 1/2 inch bolt the wrench size used on it is larger than the shaft size and that's my point. If an extractor is sized in reference to the nominal shaft size then it seems to me a 1/2" extractor would/could be to small to fit a 1/2" bolt with hex head intact. That just doesn't seem very logical. I don't mean to be a smarty pants but am still not convinced that socket type bolt extractors are sized in reference to the nominal dimensions of the bolt or stud shaft. Heck I don't know. I'm still confused by the descriptions I've read. I assume you are speaking from experience are right but would like to be sure before I pick up a set.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
