Favorite Diesel Fuel Additives
   / Favorite Diesel Fuel Additives #201
Since when is asking to see good data evidence of bias or flawed reasoning?
It isn't ... and, of course, I never asserted that it was ... so: straw man ...
But unfortunately (for you) that isn't the only thing you've done in this thread.
You appear to have an opinion (fuel additives are, to some degree or another, snake oil) ... and since it's apparently a very devoutly-held opinion, it has given you an agenda ...
Since you have offered no tests or conclusive studies which show that is in fact the case (that reputable diesel fuel supplements are snake oil), you're treading on some fairly unscientific ground ...
Which is what makes it fairly ironic ... as well as rather amusing ...
I could go through and pick a lot of what you've previously posted in this thread apart, in terms of the flawed reasoning, but fortunately (again for you) I simply don't have the time at the moment.
Lucky you.
BTW ... if you are really big on this "discounting anecdotes" thing, would you then advise that we discount/ignore your considerable comments on the subject of grapples ?
I mean, after all, they are just ... anecdotes ... :rolleyes:
   / Favorite Diesel Fuel Additives #202
and just to think, if folk had only BELIEVED the fuel additive ads of the 60s and 70s their '73 Torinos would still be around.
STP stood for WHAT ?
Ooops, it seems to still be on the market and I think I saw a diesel powered Oldsmobile less than a month ago.
Of COURSE fuel suppliers blend up their own mix and for their own good it had better be adequate - perhaps not IDEAL, since the profit motive dominates, but my trucks aren't destined for a million miles anyway and my tractors will almost certainly outlast me WITHOUT the addition of snake oil (subtraction of cash from my pocket for that) in their tanks .
   / Favorite Diesel Fuel Additives #203
In Order Of Performance - starting with the best bang for the buck:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe痴 Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
That full report has been posted on here, and is commonly cited on diesel sites.
It's getting a bit dated (formulations have changed by now), but the attention paid to it underlines the concerns people have, and hunger for data.
BTW b&d, care to answer the question I posed ? How many road-going diesels do you prensently own and maintain ?
Rgds, D.
   / Favorite Diesel Fuel Additives #204
BTW b&d, care to answer the question I posed ? How many road-going diesels do you presently own and maintain ?
Rgds, D.
What does that straw man question have to due with snake oil additives. Other than IPA and on occasions a dose of cetane in old summer fuel for winter use. #2 should not be considered acceptable for winter use in any circumstances and only considered for emergencies. The summer stuff has wax in it which will gell, no questions about it in cold weather. My Detroit Diesel by design does keep the fuel warm and is tolerant compared to my JD. No other brews, potions or elicitors are required besides the IPA and occasionally cetane booster. The rest are placebos to feel good.
   / Favorite Diesel Fuel Additives #205
I've been using Stanadyne All Season Performance Formula for almost 15 years, initially for the reduction in cloud point(gelling point) for my pre 1980's farm tractors. Lately my reasoning has leaned towards the lubricity factor and also the cetane boost(up to 6 points) as my diesels range from 7500 to 11000 hours usage and anything I can add to make the fuel fire easier in these old units is welcome. It is also recommended by many engine manufacturers. I would caution against using PS 911 as a regular use type additive as the label says to use only in a frozen/gel situation- adding a half fill to the filter/water separator and topping off with clean(room temp.)diesel fuel. It also contains alcohol which may be harmful to late model injection systems. Thanks- Mark N.
:Deere 4440,2940,730 (2x) and Fordson Power Major
   / Favorite Diesel Fuel Additives #206
As nmark alluded to. read the label. If the fuel de-icer contains methyl alcohol it's going to ruin any gasoline fuel injection system and any common rail diesel system. It's not even a good idea in carburated or old mechanical pump diesel systems.
The only alcohol to pour into a tank is 99.9% isopropyl.
   / Favorite Diesel Fuel Additives #207
Let's go with urban dictionary, but feel free to correct to a def'n I'm missing...
straw man:
A logic fallacy involving the purposeful misrepresentation of an argument in order to strike it down.
Although some posters seem confused by the title, this thread is nominally about diesel fuel addtives.
My question relates pretty directly to whether or not you have any Skin in the Game. How is asking what type/era of diesel you own a Straw Man ?
You constantly post about how you have absolutely no use for any post-emission diesel. Frankly I'm surprised to find that you own anything that will run on something other than Bunker C.
If one owns nothing newer than a Lister, then all of this "additive PT Barnum stuff" is a Don't Care, as it has little relevance to the application - I get that.
I asked the question to establish context, but will refrain from doing so again.
Rgds, D.
   / Favorite Diesel Fuel Additives #208
3930 how can you still be asking questions when the answer was posted?
Ford 3930
1990 - 2002 30 Utility Series
That is not a common rail diesel. IPA, winter diesel and a block heater is all she needs.
   / Favorite Diesel Fuel Additives #209
Ford 3930
10-4.
Rgds, D.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
90018 (A48082)
90018 (A48082)
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
