Geothermal heat pump install with crawlspace encapsulation
   / Geothermal heat pump install with crawlspace encapsulation #61
1. Cave-ins: the trenches have been caving in. This is mainly because of the wet weather combined with my soil composition. Understandably, a man doesn't want to get down into a six foot trench to put in piping if it might cave in. .
If they are working in a trench that deep (I believe a 5' deep or deeper trench requires a trench box) without a trench box (a device used to keep a trench caving in and killing someone) And OSHA comes out or, someone is killed. That contractor is in trouble. When I have to dig that deep for plumbing. I have to rent a trench box
I thought about that, but I wondered how a trench box would work in a trench where you are attaching hoses to the sides?
   / Geothermal heat pump install with crawlspace encapsulation #63
I have no idea. There are several type trench boxes, but OSHA isn't concerned with that as much as they are with safety. I have some plumber friends that have paid hefty fines for not using trench boxes. It wouldn't be your problem. Compliance is the responsible of the contractor. Last month about 40 miles from me, a plumber's helper was killed when the trench /hole he was working in collapsed. They were working on the weekend trying to avoid permits / and safety regulations/requirements. I would make sure he (the contractor) has plenty liability insurance, incase something happens to 1 of his employees on your property
   / Geothermal heat pump install with crawlspace encapsulation #64
I was thinking the same thing. Especially the insurance part. Seems like I have seen boxes with just legs for the bottom 2 feet or so.
   / Geothermal heat pump install with crawlspace encapsulation #65
So is he charging you more for boring since they couldn't dig trenches and since there was debris in the loop field excavation area? Are they grouting?
What brand of heat pump?
   / Geothermal heat pump install with crawlspace encapsulation #66
Any updates or are they still trying to dig? :eek:
Sorry I haven't been keeping up with the updates. I had some business travel and there have been some delays in the project.
They are still doing the boring. They started the boring and got two lines done when the boring machine had a hydraulic cylinder break. It took a few days to order a new one and get it installed. Then we had torrential rain for a few days and it was too wet to work. They just re-started the boring work today.
To answer the other question, they are not charging me more for the boring because it was their decision to switch to that. I realize that also might have something to do with why it's going kinda slow.
Re: grout they are not grouting because the boreholes are "self-grouting." The borehole isn't much larger than the line being pulled through and they are using high pressure water as part of the boring process so it muds up and settles around the line. I think that's right. It was explained to me a week or so ago and that's my memory of it.
I have some pictures that I will try to get up in a day or so.
   / Geothermal heat pump install with crawlspace encapsulation #68
I had geo thermal installed last week. I'll share a little bit about my system. Its a 4 ton unit with the backup heat being electric. We had propane heat before and I wanted to do away with it altogether. We also have a wood fireplace for emergency heat during a power loss. I would also be worried about hooking up a generator since it seems like it has some sensitive electronics.
They did directional boring for the piping. There is a company that does nothing but geothermal and they came in and did it in a day. The even directional bored the piping into the middle of my basement where the furnace is installed. It took them about 3 days to install the furnace, hook up the duct work to the old ducts and install a hot water storage tank and a new electric water heater. Its my understanding that the water storage tank will preheat the water depending on if you geothermal is running or not.
Rough numbers, $20,000 total for the installation and equipment cost. We will get about $5500 back on tax rebates etc. A conventional LP and AC unit could have been installed for about $5000 to $7500 depending on the quality of the unit. We pay about 8 cents a KW hour for the geo while the normal rate is about 12 cents.
Rough numbers for energy usage, our house is 1900 sq ft with a full basement. Climate, we are about even north and south with Peoria Illinois. House has new windows and probably average insulation. $990 a year for heat, hot water, AC. The number that blows me away is the total AC cost for a year is less than $100. Other people told me this also, the AC part of the geo is almost, but not quite free. Roughly a third of the yearly bills is for making hot water. They are estimating the return on investment compared to a convential LP furnace and AC unit to be 3 years.
All and all I'm pretty happy with the unit. It hasn't been very cold here yet so the unit hasn't run much for heat and I ran the cold side of it one day just to see how it works and it seems good.
Finally have some down time with the computer to put up some pictures. As I said earlier, the ground loop contractor started with a plan to dig 7 trenches but abandoned that after the first trench because of cave-ins and running into junk that my clearing contractor buried 16 years ago so they switched to boring. They are boring 12 runs 150 feet long and 10 feet deep. It has been frustratingly slow work, they are getting about 1 to 1.5 bores done a day. This is mainly because of frequent equipment breakdowns and the distance from my place to parts stores or service that they can use. However in the end I think this will be better because it's must less ground disturbance, and the lines will be deeper (the original trench plan was 6 feet deep with lines at 6 feet and 4 feet.
I found out the plan had changed when the boring machine showed up at my place.
They dug two trenches, 3 feet deep, 150 apart, parallel to each other and the bore from one to the other.
Here is the boring machine in position to dig:
The borer, from the front:
This "aerial" shot (from the roof of my barn) shows the whole operation. The piles of dirt at the far end of the pasture are the far trench that they are boring toward, from the trench at near end. The dirt area to the left is the one trench they completed before switching to boring.
During the boring, one man operates the machine and another guides it using some pretty sophisticated electronics. The tip of the drill contains a precise transponder (they told me the transponder is costs $3K!) and his assistant uses this detector to keep track of where the bit is (laterally and depth) and give directions to the driller to keep it straight.
Once the drill pokes out of the far trench, they attach the geo line to it using "chinese fingers" and then pull it back through.
Here's a picture of the header trench with several of the lines completed. They aren't worried about the water, in fact wet soil conducts heat better than dry, apparently. My land does not perk, and this water is from rain over a week ago. They will pump it out when it's time to assemble the manifold.
That brings us to present day. 8 of 12 bore lines have been completed. Looks like at least another week of fieldwork to go.
They bored to the house today and got the supply and return lines into the crawlspace. There is still some fieldwork to do, need to finish testing the installed lines and then button the pasture back up. I talked to the field work contractor, he said my job was interesting because it turns out I have a layer of solid bedrock about 10 feet down. That holds water, which is why my trenches were so prone to cave-ins. But the good news is that the perpetually damp soil will conduct heat much better than dry soil would.
Ironically the propane tanker came today and made a delivery while they were working on the line to the house. Even more ironically, the gas was the cheapest price it's been in about 5 years... $1.91/gallon. Long term I know geo is still the way to go but interesting that gas is getting cheaper now. Well for now at least, I doubt that will last.
I didn't really do a good job of keeping up with this but I did want to close it out. They finished the install and turned on the geothermal system on Friday, November 14th. That night the temperature plunged and we've had several mornings of temps below 20 degrees since then. The system has loafed along, it easily kept the house at 70 degrees with no aux heat used (I know no aux heat was used because I have it set up so I have to manually turn it on). I still don't regret getting the aux heat because my main reason was to have something I could run off a generator during ice storm power outages.
As part of this project I also had the crawlspace encapsulated. It was a mess down there because critters had figured out how to pull off the crawlspace vents and had been getting under there during cold weather, and tearing up the fiberglass insulation and the flexible ducts to nest in the material. The encapsulation guys found a skeleton of the possum down there, as well as plenty of other mess that you can expect where wild animals live. I also had a top-end whole house air cleaner installed (Trane CleanEffects) and the cumulative effect of the encapsulation and air cleaner is like a new house. Bad odors in the house that I thought were caused by my pets literally disappeared overnight. Allergies and minor respiratory problems also disappeared virtually overnight. I can't recommend this enough!
Some pictures:
This is the old condenser coil, showing the rust and mold that results from being in a vented crawlspace in a humid southern climate, for 15 years. Yuck, we were breathing that!
The Geothermal compressor in the crawlspace. Notice the plastic below, the rubber mounts, and no insulation between the floor joists (because the crawlspace is now sealed and insulated)
Geo lines going into the crawlspace. They did not bore directly into the crawlspace because there are so many piers under there they were concerned about how deep they'd have to go and getting the lines up into there without doing any damage. So they bored to about 5 feet from the crawlspace and then hand dug a trench to the crawlspace wall and punched it in there.
This picture gives an idea of what the crawlspace encapsulation entailed. You can see the plastic on the ground that goes up the wall behind the R-10 insulation board that is attached to the block wall of the crawlspace. The very top is left uncovered for termite inspection.
   / Geothermal heat pump install with crawlspace encapsulation #72
Looks good. I bet the guys had a fun time wrestling the geo unit into place under the crawl. Hopefully it wasn't too far from the hatch.
   / Geothermal heat pump install with crawlspace encapsulation #73
You probably want to insulate those pipes or you will get a lot of condensation.
I shouldn't. The crawlspace was sealed and insulated as part of this work.
   / Geothermal heat pump install with crawlspace encapsulation #75
I have a geothermal Tranquility 27 unit with aux heat under my crawl space, too. Been very pleased with its performance. I hope you will be equally pleased. If you haven't found a good supplier for those jumbo filters it takes, let me know. I'm happy with an internet company I've been using.
But I had never heard of encapsulation until a couple of recent threads. I'm fascinated by it. Do you have conditioned air pumped into the space via your ductwork?
   / Geothermal heat pump install with crawlspace encapsulation #76
It will condensate especially in the winter on the return lines. I promise ya. Been around Geo many many years.
   / Geothermal heat pump install with crawlspace encapsulation #77
The loop temps in the winter can easily fall below the dew point and start sweating. My geo units are in my dry basement, which is usually about 65 deg in the winter, and the loop lines started sweating quite a bit until I insulated them.
paul
Yes, two register openings in the ductwork in the crawlspace.
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
2019 FORD F150 STX CREW CAB TRUCK (A59823)
2019 FORD F150 STX...
DEUTZ MARATHON...
