mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,362
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Max 28XL Custom 3 point attachment 2" reciever, Weight Box, Tool Carrier/work table.
I am putting forth a group buy offer for a custom fit 3 pt. hitch combination weight box, heavy duty 2 hitch receiver, work platform designed to fit the Mahindra Max 28XL.
What is unique about the attachment is that it is multi purpose and not obtrusive. Being specifically designed around the Max 28 the attachment is very compact, nesting nicely within the spread of the lower stabilizers.
The 2 receiver extends only 6 beyond the lower stabilizers.
I measured the Max 28XL OAL with the loader bucket 18 off the floor. It measured 15?3 long x 54 wide, The Max 28 tractor seems on the large side of a æ•—mall compact tractor.
A main goal of my design is not adding significant length on hinder maneuverability.
The weight box is designed to hold a poured trapezoidal concrete block, that weighs 375 Lbs per foot of height. If you pour an 18 tall block including the weight of the attachment, you will add over 650 lbs ballast to the tractor.
If less ballast is need several 16 x 16 pavers can be stacked and held together with some ratchet strap tie-downs.
The kit will include will 4- ï½½ stainless steel concrete anchors for bolting the an monolithic concrete block to the floor of the attachment. The attachment itself weights over 90 lbs, and is constructed of .25 minimum 3 X 3 and 3 X 2 A36 L Angle. The floor is heavy gauges expanded metal with flat bar support.
To load and remove the block, removable lifting eyes or some U shaped rebar cast in a pocket can be added for lifting while slowing the top of the block to be flat.
Removal of the entire attachment with or without the weight should be as straightforward ad connecting any implement to the 3 pt hitch.
Included are bolting provisions for mounting a back work bench tool carrier to the top of the attachment. I知 planning to use the cargo carrier as my tool tray, just grind off the receiver tube and mount to the angel at the top link on the front and a pair of support legs in the back.
For example:
Amazon.com: 48" Hitch-Mounted Cargo Carrier Gear Tray & Hauler Rack: Rage Powersports: Automotive
I値l also be able to haul firewood with a larger carrier I have mounted in the 2 receiver.
2 Receiver and the cross beam specifically designed for use with the Ripper Sub-Soiler for Three Point Hitch Receiver described below
https://heavyhitch.com/store/heavy-hitch-accessories/heavy-hitch-ripper/
I have an old small snow plow blade that I am going to attach to the receiver for snow clean-up around the buildings.
The attachment allows positional control and will be furnished with a special Cat 1 short upper link. The bar for the lower stabilizers is .875 dia. 300 Series Stainless.
Being winter and I have other items on the agenda to outfit my Max 28 tractor for the hard life it will live, I値l keep this on this forum to Until Jan 20, 2015 to determine if anyone else feels this is worthwhile to go in on.
I have decided a weight box is a better choice than loading the tires as Rotary cutting a muddy field or working on soft ground you have a lighter tractor that as necessary can add a lot of ballast.
Although you do not have to usually deal with them often, Loaded tires are quite the pain.
Please PM me if interested or have questions or comments.
PS
I've increased the brace to the uprights for the renderings posted.
For example:
PS
3 X 3l L Angle Wieight Box _ISO View_Top Link End_Weight.JPG264 KB · Views: 1,748 -
3 X 3l L Angle Wieight Box _ISO View_Hitch End_ Bot With Block.JPG318.4 KB · Views: 981 -
