18" BX25 Backhoe bucket
   / 18" BX25 Backhoe bucket #11
I destroyed my 10 bucket on my 23 I had to totally rebuild it here it's so rocky here I've found a small bucket digs better I get a rock or root in every bite
Nice work. Now you just need to fab up some kind of quick change system so you can swap buckets real fast. A member by the name 4shorts made one for his BX25 and put a video on youtube. Seems he doesn't post here all that much anymore, but you might check out his youtube video for more ideas. Again, nice work.
Ya I know Paul I've bin watching his videos for a couple of years. He didn't like it when someone copied his quick coupler as I seen all the drama from the posts on this site about it. It only took me around 5 minutes to change my buckets. Take out the single bolt for each pin an the pins pull out an put the other bucket on. I asked Paul why he took most of the pictures down on this site an he said that something was going on with his photo bucket account.
Ya we have some rocky soil around that's why I went with the 100,000 yield steel for the sides/ scrapers an the Hardox for the main cutting edge. I'm going to build a 8" bucket out of the same steel in the spring. I'd rather over build it then have to repair it all the time.
   / 18" BX25 Backhoe bucket #14
I realized quick how important it is to inspect your bucket daily.one stress crack one minute and your tearing it open like a beer tab the next
   / 18" BX25 Backhoe bucket #15
Can you provide a little more info on using your bucket to muck out ponds....I have a 16" bucket and also find the crud just sticks. A lot of blue clay in the swamp....
I have the same problem. We were digging in clay with my 12" bucket an tried smearing grease inside the bucket an it helped for about 3 scoops till it started wearing off. There is not much you can do I guess.
   / 18" BX25 Backhoe bucket #17
Yeah, but its fun playing around with it....really fun. In dirt, its a BLAST! I planted over a hundred trees, dug out stumps, pulled old fence posts, trenched a drainage ditch, and moved big rocks. That was just the first year!
   / 18" BX25 Backhoe bucket #18
Google 'clay bucket' for your really wet work. Basically a bucket with no sides, well just enough to give some rigidity to the back. Only good for soft, mushy work and no rocks as they lack the strength of a regular bucket but just the ticket for the pond work. Not having sides reduces the suction.
That's also the reason that your standard bucket has tapered sides to it -- to help keep material from jamming in the back
   / 18" BX25 Backhoe bucket #19
Nice build on the bucket. Clever using the original bucket as a form to make the new one.
image-171509007.jpg image-934769932.jpg image-4194637620.jpgweather got good enough to put it back on an do some digging. The bigger stabilizer pads work great and are removable with one t bolt. image-2140072089.jpg
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Walking Floor Trailer (A50322)
Walking Floor...
