Thinking of customizing my 3ph winch
   / Thinking of customizing my 3ph winch #1
namesray
nc PA.
kubota rtv900: kubota mx5200
This year I have been fighting mud on the fire wood logs I have been skidding out. It seems my fransgard winch isn't designed well for "skidding". It does great on "winching" the logs to the road, but I have always struggled finding the best method for "skidding" the logs to the landing, especially this year with all the mud. I have been sharpening the chainsaws constantly, as the logs get caked with mud. The factory design of the winch states to use the lower "tow bar" to hook the chains into and DO NOT use the cable for skidding. ok, but leaving the logs on the "tow bar" keeps them too close to the ground and thus the mud.
So next, I left the logs on the cable, and raised the butt ends up to the "dozer/anchor blade" at the bottom of the winch. (dozer/anchor blade is designed to place butt end of the logs against). doing this helped, but still after raising the 3ph to its fullest height, the logs are still too close to the mud.
Then, I started cutting the logs shorter (10ft lengths) to raise the angle of the log off the ground more. this worked "better" but was so inefficient as I spent so much time preparing the logs instead of just getting them to the landing.
So now to my point/question. The other day I started winching the logs all the way up to the upper part of the winch. above the dozer/anchor blade. This seemed to work great! However the winch is not designed to have a butt end of a log "banging" into this area. All the moving components of the winch are attached in this upper area, such as the drive shaft, and am concerned that one too many "bangs" in this area will bend the "frame work" for these moving parts and ruin the winch.
I am considering of attaching an upper skidding plate in this upper area of the winch to protect the frame work and moving parts. My theory is using a 10" I beam, placed vertical, welded on each side of the I beam to the winch. The gap behind the I beam would keep the log banging off the actual winch framework and the area of impact would be absorbed over a larger area= the welded area of the I beam where it attaches to the winch.
Any thoughts or suggestions??
Here is a video of a 3ph winch in action, so you can see how close to the ground and mud the logs are unless you were to pull the cable/log all the way up the winch. (not a fransgard winch video, but same operation)
The actual "skidding" portion of the video starts at about the 2 minute mark if you would like to fast forward to it.
Take note as to how close to the ground the logs are left by skidding according to the winches intended design. The ground in the video is pretty dry, just imagine if that was all mud and you had to cut those logs up with your chainsaw later. The saw won't stay sharp very long!
winches skidding - Bing Videos
Some quick illustrations of what I am thinking.
   / Thinking of customizing my 3ph winch #4
Well Ray here's my take on all this.
I have a Farmi winch, Had it since 1978 and used it every ady since then. Its probably dragged out 20,000 cord of firewood, numerous vechiles and such. It has been used very hard and has broke 1 of my tractors rear end housing in half. No damage to the winch :laughing:
This is one tough piece of steel here. Watching the video yours and mine are made similiar except i don't have a blade. Mine has 2 legs instead. I have never dragged loggs from the lower chain holds, its always from the top roller. Some of my skidds this year were a half mile each way, pulled 500 cord that way so far this year. yea, the logs bang in to the frame but its heavy enough to with stand the use, paint is bummed up but, its only paint, i buy equipment to use, not to look good and no my tractors dont get waxed either :laughing: This year i am using the winch on my Kiot iDK 35SE for the simple reason it has a better seat , easier on my body.
First picture is a part of what i have dragged out this summer, the others are of my winch. . . . .This is how iv'e done it for years . . .John
   / Thinking of customizing my 3ph winch #5
Jpm1,... Nice pile of wood,
I too have a Farmi and use it in the winter mostly to get out saw log's and my fire wood. I too let my load dangle from the top roller some but have always worried about the weight on the main shive/ roller pin. But unless I drop the twitch and remove the cable chokers then re-hook the logs with chain to the tow / slotted bar the load would be very close to the ground. I don't worry about mud as the ground is frozen when I am cutting . The twitch moves sooo much easier with the buts up off the ground.
   / Thinking of customizing my 3ph winch #6
We must suppose that the "No Skidding from the winch rope" warning is due to safety concerns.
High point pulling is NEVER a good idea. Tractors are known to rear over backwards and kill their drivers that way.
Then too, I suppose that it might be possible to pull the rope so tight that it wedges in under the outer spool windings and make a mess out of letting cable out when it is next needed.
But, IF you promise not to snag the butts (which should be easy if they are four feet off the ground ;-) And if you promise not to pull trees without at least half cutting the branches so they can fold back, I would say, do what you want, the winch won't be hurt a bit by some added metal!
cheers
   / Thinking of customizing my 3ph winch #7
I read online that part of the concern with using the top pulley to haul out is the additional stress on the top link - and that can cause a failure on the tractor (or obviously impact the toplink)
   / Thinking of customizing my 3ph winch #8
https://www.youtube.com/watch?v=CeyHJil9qXQ
Why you pulling from the bottom pulley, I didn't buy that when I got my winch, I had a thin steel plate where the pulley attachment would go, I took that off, copied it to a thicker piece of steel and put that on. I always winch to the top pulley, and if I have to go around a corner that might tipper the tractor over, I lower the winch down till it almost hits the ground. I haul out big logs and they bang into the upper plate, I mean BANG!, nothing broke yet, and I get my 10 cord of firewood out during the winter when there's snow on the ground so the wood will stay a lot cleaner, and haul a lot faster.
Also if I haul logs out in the summer or when it's muddy, that story is part II
Oldpath05, that is a nice set up you have there. That is a L3400 kubota?!! Very nice the way you have all your tools setup on it. Thanks for the video and YES I want to hear "part II" of the story!
Like you say, pulling from the bottom pulley or tow bar does not work for keeping mud off. And I dont have the luxury of doing all my firewood in the snow, as I am now doing over 400 face cord per year. Its an all year/seasons thing for me. My last 2 wood plots are wet any way and this past year was real rainy in northern pennsylvania.
As for too much strain on the top link by skidding from the top pulley, that doesnt concern me. The tractor is holding up to it well over these years.
When pulling from the top pulley, yes sometimes the ouuer most wrap of cable does get pinched down into the other wraps on the drum, but only happens once in awhile.
I have not done any upper skid plate modifications yet. My b7800 3ph lift is not that great for lifting the weight and all the weight of the logs up, so I did not want to add more weight to the winch by welding a plate on. I have been considering a much larger tractor, with more 3 ph lift, in hopes of 2 things. One, for the bigger tractor to be able to lift the winch and hitch higher then my b7800 can and two, if that still is not enough, the bigger tractor 3ph rating can lift any modification I weld back there along with more logs then my b7800 can.
My main concern with not having extra protection on the winch is the logs banging WILL bend or dent something that will ruin the winch. Its onlt 3/16 thick on the winch up there. Also, the upper part of my winch isnt very wide and on sharp switchbacks, the logs come out from behind the winch and bang into the side of the winch.
Hopefully if I get a larger tractor, it will just lift the winch and hitch higher the way the winch was orginally designed, but somehow I doubt it will be that easy.
   / Thinking of customizing my 3ph winch #10
There's a slight hiccup with part II of the story, last summer my son took some pics. with his smart phone, but couldn't get the pictures off that stupid card, (do over) this spring.
But last summer I wanted to find a way of getting the logs less muddy so I can save some time debarking at the mill. I started taking my trailer in the woods near the logs, it has 4, 2-1/2 foot high stakes, and I find a level-ish place to park it. Then go cut the logs down, winch them to the tractor, drag them to the trailer, load them with the bucket, I can haul more on the trailer and I was keeping them a lot cleaner that way. The longest I can haul on the trailer is 25 feet, then put a few shorter ones on top.
The moral of the story is, the best way I know of to keep wood clean when it get muddy and haul more with one trip, is a trailer/wagon. I also noticed it's a lot faster unloading than loading. So if this is going to be an ongoing operation with that much firewood, I'd consider a trailer capable of supporting a small pulp loader that can be added on some day, or if next week you win the lottery, you could then go buy a small trailer with a log loader on it, and give me a percentage for this outstanding idea.
Rhino DB150 (A57148)
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A59905)
2015 UTILITY VS2RA...
