what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #181
I wonder if everybody is using the same methodology I am. I calculate the rate including all the charges, simply take the total and divide it by the KW hours used. To me, that's the real rate.
   / what on earth does electricity cost near you? #182
Good point... I think I will go back and compare mine w/ and w/o taxes, fees and see how much that difference is? Our rate is graduated based on usage thresholds, so it isn't just a couple numbers to look at.
   / what on earth does electricity cost near you? #183
You might want to lock up the liquor cabinet before doing the bulk Total $/Total kwh calculation.
The last time I did that here, it was, to say the least, depressing.
Gotta go, as I'm now packing to move to KS...... :us-kansas:
Rgds, D.
   / what on earth does electricity cost near you? #184
That is exactly how I figure mine. Works out to ~$0.12/Kwh for about 1000-1500kwh usage. If usage is more, like 3000kwh, it is a little less. Drops down to around $0.11/kwh
   / what on earth does electricity cost near you? #185
Yep, I do the same. I was supposedly on a rate of 10.5 cents per KWH last year, and the actual cost for the year came to $0.11125228 per KWH. On a month to month basis, it varied from $0.1058333 to $0.13086044 per KWH. And now I'm on a 9 month plan that makes the base cost 9.4 cents if I use 2000 or more KWH per month to 12 cents for 1000 to 20000 to 14 cents for 500 to 1000.
   / what on earth does electricity cost near you? #186
That is exactly the way I figure my cost per KWH.
Our cost is 12-13 cents per KWH. Moving more towards 13 cents.
Later,
Dan
   / what on earth does electricity cost near you? #187
I do it by the total also. Around $.105
   / what on earth does electricity cost near you? #188
mine is .069
locked in till Dec. 2015
   / what on earth does electricity cost near you? #189
Not that anybody will be surprised....
Ontario is raising its hydro rates again Saturday as time-of-use electricity customers switch over to the winter hours schedule.
That means running a dishwasher or clothes dryer in peak hours 7-11 a.m. and 5-7 p.m. will gobble up electricity at the rate of 14 cents/kWh.
Middle-of-the-day hydro, 11 a.m. to 5 p.m., will cost 11.4 cents/kWh, while overnight, weekends and holidays will set users back 7.7 cents/kWh.
Rgds, D.
Nothing wrong with that.
If you have a power hog like a water heater, set it to run off-peak with a timer @ 7.7 cents
   / what on earth does electricity cost near you? #190
We don't have the step levels here. In my case, it works out to 14 cents per kwh. If I used a bunch more, it would decrease a little bit, because one of the charges is fixed. But very, very little....
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A55315)
2020 John Deere...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
JOHN DEERE 6130M TRACTOR (A57192)
JOHN DEERE 6130M...
(2) ROLLS OF MISC CARPET (A54757)
(2) ROLLS OF MISC...
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
