what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #181
I wonder if everybody is using the same methodology I am. I calculate the rate including all the charges, simply take the total and divide it by the KW hours used. To me, that's the real rate.
   / what on earth does electricity cost near you? #182
Good point... I think I will go back and compare mine w/ and w/o taxes, fees and see how much that difference is? Our rate is graduated based on usage thresholds, so it isn't just a couple numbers to look at.
   / what on earth does electricity cost near you? #183
You might want to lock up the liquor cabinet before doing the bulk Total $/Total kwh calculation.
The last time I did that here, it was, to say the least, depressing.
Gotta go, as I'm now packing to move to KS...... :us-kansas:
Rgds, D.
   / what on earth does electricity cost near you? #184
That is exactly how I figure mine. Works out to ~$0.12/Kwh for about 1000-1500kwh usage. If usage is more, like 3000kwh, it is a little less. Drops down to around $0.11/kwh
   / what on earth does electricity cost near you? #185
Yep, I do the same. I was supposedly on a rate of 10.5 cents per KWH last year, and the actual cost for the year came to $0.11125228 per KWH. On a month to month basis, it varied from $0.1058333 to $0.13086044 per KWH. And now I'm on a 9 month plan that makes the base cost 9.4 cents if I use 2000 or more KWH per month to 12 cents for 1000 to 20000 to 14 cents for 500 to 1000.
   / what on earth does electricity cost near you? #186
That is exactly the way I figure my cost per KWH.
Our cost is 12-13 cents per KWH. Moving more towards 13 cents.
Later,
Dan
   / what on earth does electricity cost near you? #187
I do it by the total also. Around $.105
   / what on earth does electricity cost near you? #188
mine is .069
locked in till Dec. 2015
   / what on earth does electricity cost near you? #189
Not that anybody will be surprised....
Ontario is raising its hydro rates again Saturday as time-of-use electricity customers switch over to the winter hours schedule.
That means running a dishwasher or clothes dryer in peak hours 7-11 a.m. and 5-7 p.m. will gobble up electricity at the rate of 14 cents/kWh.
Middle-of-the-day hydro, 11 a.m. to 5 p.m., will cost 11.4 cents/kWh, while overnight, weekends and holidays will set users back 7.7 cents/kWh.
Rgds, D.
Nothing wrong with that.
If you have a power hog like a water heater, set it to run off-peak with a timer @ 7.7 cents
   / what on earth does electricity cost near you? #190
We don't have the step levels here. In my case, it works out to 14 cents per kwh. If I used a bunch more, it would decrease a little bit, because one of the charges is fixed. But very, very little....
2015 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A52707)
2015 CATERPILLAR...
2004 Winnebago Sightseer 30B 30ft. Class A Motorhome (A55853)
2004 Winnebago...
2005 Ford F-150 Ext. Cab Pickup Truck (A55852)
2005 Ford F-150...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
Bobcat T590 (A53317)
