My test of a rubber scraper vs a pipe on the blade edge results
   / My test of a rubber scraper vs a pipe on the blade edge results #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
thought I'd try out putting a couple edges over the normal steel edge to see if I could keep the rocks off my grass and keep from hooking the sod also..
I started with a 1 1/2" pipe with welded on tabs and bolted it to the blade, if you had level ground to plow, it would be alright as you can put down pressure on it vs the rubber belt.
secondly I tried a 1/2" thick piece of conveyor belting on with an inch protruding, First I did my small deere 425. and was impressed as it was like a squeegee over grass or gravel. then I put some on my 5 ft blade I installed on the loader of a BX2360. again, it was impressive vs the steel edge.. the loader mounted one isnt the best for off level conditions though, as there isnt any slop in the setup to allow it to follow the contours, and because of the long arm ,a little movement of the tractor will put the blade offlevel more..
So the winner was the rubber belting...
   / My test of a rubber scraper vs a pipe on the blade edge results #2
Sounds interesting. Got any pics?
   / My test of a rubber scraper vs a pipe on the blade edge results #3
I have thought of doing that but here we get a hard crusty snow sometimes that is hard to break through with the regular cutting edge, so I just walk along my drive after the snow melts and rake the stones back into the drive.
anyone know a free pic hosting site,, my other one started charging..
   / My test of a rubber scraper vs a pipe on the blade edge results #5
No need to host pics anywhere, just attach them to a post.
   / My test of a rubber scraper vs a pipe on the blade edge results #7
There's also....tinypic.com
   / My test of a rubber scraper vs a pipe on the blade edge results #8
I did have to obtain software to resize my photos but no hosting site needed. Just click on "insert image" icon and go for it.
AND I have tried a chunk of heavy duty PVC pipe on my rear blade cutting edge. I was totally surprised - after being cut/slit lengthwise and slid over the cutting edge, it stayed on, worked great but, unfortunately, did not last long. The gravel driveway was just too abrasive for the PVC pipe.
   / My test of a rubber scraper vs a pipe on the blade edge results #9
What is the best way to cut rubber like a stall mat?
   / My test of a rubber scraper vs a pipe on the blade edge results #10
I was just wondering if a stall mat would be comparable to a conveyor belt? Maybe a bit thicker and less flexible?
Best way I've cut them is with a reciprocating saw (sawzall). (Though there might be some blades that would work with a circular saw.)
I was thinking of using a strip of mat as a replacement for the chain guard on my brush hog?
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
toro turf sweeper (A50324)
toro turf sweeper...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
