Co-worker with 6.4 Ford Power Stroke problems.
   / Co-worker with 6.4 Ford Power Stroke problems. #101
".. Metal in the fuel filters..."
I don't much about these things, but I would assume the fuel filters are upstream from the injection system; does this thing have a low pressure fuel pump upstream from the filters? If not, then the shavings would have to originate somewhere other than the engine, correct ???
Its my understanding there is a fuel filter before and after the high pressure fuel pump.
I've never seen the truck so I have no idea, but I thought I read somewhere the second filter was after the high pressure pump. This would make sense otherwise why have two?
   / Co-worker with 6.4 Ford Power Stroke problems. #105
I don't know, the injector pump creates thousands of psi (at least I think so) not sure how many filters could handle that.
Yes, that's true, I think most common rails run in the 26,000 psi or more range. The only way a filter would handle that would be if its on the return line to the fuel tank.
   / Co-worker with 6.4 Ford Power Stroke problems. #107
i believe there is a filter/water separater, low pressure pump (10-15psi), smaller micron fuel filter, high pressure pump
   / Co-worker with 6.4 Ford Power Stroke problems. #108
Is there a return line after the injector pump?
Edit... I'm thinking about this wrong I guess, I'm still thinking old school diesels where there is a mechanical pump with line going to each cylinder. On the new diesels I guess there could be a return line, I don't know.
   / Co-worker with 6.4 Ford Power Stroke problems. #109
With so many horror stories including mine with diesels I wonder why any of us even buy them any more.
I don't know a lot about the Ford diesels but most modern diesels are a common rail and very high pressures. Most of the fuel being pumped is sent back to the tank. I'm not sure, but the mechanical injection om my little Kubota diesel has a return line.
17307 (A55853)
17307 (A55853)
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
