Question for the rock and gravel guys
   / Question for the rock and gravel guys #21
That looks like limestone. IF in fact it is, you should wet it down and then roll the he!! out of it. It will harden right up.
It's light colored due to a light coat of dust, but it's trap rock / basalt. We have lots of it, here.
   / Question for the rock and gravel guys #22
Are you going to top-coat it with anything? or is it just for tractor passage?
Last load of stone I got was over 50k:confused2:
It's a fairly short driveway to a detached garage where the 2 newer tractors sleep, so only our own, low speed, car & tractor traffic.
I may get some finer, mixed size rock and top dress, if it needs it.
   / Question for the rock and gravel guys #24
50K? Is that pounds of rock or dollars?
   / Question for the rock and gravel guys #25
Since you have clay as a base it can and will ooze out to the surface.
That is one of the ideal situations for GEOTEXTILE as it will allow water to pass but not the clay.
   / Question for the rock and gravel guys #26
That was weight.
Limestone. Somewhere around $400. I think it was $16 or $17 a ton
   / Question for the rock and gravel guys #27
That was weight.
Oh thank goodness. For a minute there, I was sure I was gonna have to call you and claim I'm your long lost nephew. 40K on rock?!?
   / Question for the rock and gravel guys #28
Gregfender has gotten the advice that he needed. But here's a funny story for us "rock & gravel guys".
I had bought several tons of ornamental rock (pebbles 1-3 inch) to put around the foundation of the house. It was a beautiful color and looked so cool. Thus I thought it would be cool to use for a place to park my trailer....so I hauled in some more and spread it out.
:grumpy: "Not Cool"....I had to FEL it all away because it makes and unusable surface for even walking. .... like being in quick sand.:hissyfit:
   / Question for the rock and gravel guys #29
Around here, you would use 304's for base. They are 2" down to fines and pack hard. Then top with either 411's (1" down to fines) or 57's (1" washed). Sometimes I add 411's to reshape, and then top dress with #8 for a quiet smooth surface.
   / Question for the rock and gravel guys #30
We use #2 for the base and then #57 or #8 for the top coat.
Chris
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A55788)
2009 Ford F-250...
