A little hydraulic cylinder
   / A little hydraulic cylinder #11
My gatepost by my driveway are made using hyd cylinder rods. I cut one cylinder rod in half and the length after I cut them was around 10 foot. We had 2 lathes that had 40 foot long beds on them and would turn tie bars for the die cast machines we built. Many of the hyd cylinder we built and made parts for had any where from a 12 to 24 dia head on them and various lengths
Niiiice......I've always wanted to make a mailbox post with one:drink:
   / A little hydraulic cylinder #12
Someone was thinking when they set that lathe up by the door.
That lathe weighs 13,000 lbs....after the initial install It took me almost all day to move it 3 feet to clear the door and get it leveled
   / A little hydraulic cylinder #13
   / A little hydraulic cylinder #15
Suddenly, I'm inspired to ask the guys at the local hydro-shop about rods/pieces they'd scrap. Might get a better deal than what I'm paying for stress proof to make bucket pins. (Hmm ...)
Anybody use 'em for that?
   / A little hydraulic cylinder #16
I'll tell you something else you might keep your eyes open for when it comes to pins. Truck and large engine piston pins.
   / A little hydraulic cylinder #19
"Remote" or 'Satellite' steady-rest. Ya gotta do what ya gotta do. ;)
Impressive cylinder. What is the bore and stroke on that thing?
We have a rather large cylinder at work on an aluminum press. 14" diameter and 120" stroke with a 10" rod.
That press is powered by 3 150HP motors each driving a 80GPM pump. With a 2000 gallon reservoir.
The cylinder I worked on was an 8" bore about 20" stroke with a 4" rod.
Brian
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
