Water Well Connections - Best Methods
   / Water Well Connections - Best Methods #1
Beltzington
Appling, Georgia
JD 3720
After getting prepared to build a well cover it occurred to me I still need to run at least a couple underground waterlines for a future house and a yard spigot. Seems simple enough for the simple minded but I am cursed with over thinking everything. Currently my well pump has a 1.25" PVC ball valve not connected to anything. Assuming this will become my main shutoff valve how do I split this for multiple underground runs and how do you allow some flexibility for adding additional lines in the future without having to dig up everything and basically reconnect everything. I searched for a water manifold on the net but everything I found was for commercial construction. I have power lines and many trees around my well so I am limited on where the water lines can connect. Anyone have an ingenious solution? Here is the pump.
   / Water Well Connections - Best Methods #2
For future access, every above ground ell you consider install a T and plug the unused opening to possibly be used in the future. Build your own manifold if parts are available. A word of caution using female screw fittings. Avoid if possible. Choose them carefully if they are absolutely necessary. They will crack because of the swaging force.
   / Water Well Connections - Best Methods #3
Amen to not using female plastic to iron adapters. I wound up with a major leak in the middle of January due to using one. Yup, split right on the casting seam.
Harry K
   / Water Well Connections - Best Methods #4
Harry K
I was fortunate to have better hearing 30 years ago and heard the coupling crack after hand tightening down in the trench and 2 short strokes with a pipe wrench. No guarantees with the hearing today.
   / Water Well Connections - Best Methods #5
I have 4 line manifold made from T fittings with independent ball valves for each run.
If I need more will just splice on and continue. PVC is easy to work with.
I assume everyone is using flexible PVC for underground water supply lines?
   / Water Well Connections - Best Methods #7
I recently noticed a plumber using gray fittings when replacing some PVC around a well's tank. He said he only uses schedule 80 fittings, since they are less likely to crack.
   / Water Well Connections - Best Methods #8
1 1/4" sch 40. Got a smokin deal from Lowes on 20' sticks they were trying to get out of their stores... Picked up 78 sticks for <$1.50 ea...
   / Water Well Connections - Best Methods #9
Am I missing something or would you have to cut the PVC to pull the pump?
   / Water Well Connections - Best Methods #10
Looks like maybe the 1st time but a union will fix it going forward....
DEUTZ MARATHON...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
1454 (A57192)
1454 (A57192)
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
17101 (A55851)
17101 (A55851)
