Water Well Connections - Best Methods
   / Water Well Connections - Best Methods #1
Beltzington
Appling, Georgia
JD 3720
After getting prepared to build a well cover it occurred to me I still need to run at least a couple underground waterlines for a future house and a yard spigot. Seems simple enough for the simple minded but I am cursed with over thinking everything. Currently my well pump has a 1.25" PVC ball valve not connected to anything. Assuming this will become my main shutoff valve how do I split this for multiple underground runs and how do you allow some flexibility for adding additional lines in the future without having to dig up everything and basically reconnect everything. I searched for a water manifold on the net but everything I found was for commercial construction. I have power lines and many trees around my well so I am limited on where the water lines can connect. Anyone have an ingenious solution? Here is the pump.
   / Water Well Connections - Best Methods #2
For future access, every above ground ell you consider install a T and plug the unused opening to possibly be used in the future. Build your own manifold if parts are available. A word of caution using female screw fittings. Avoid if possible. Choose them carefully if they are absolutely necessary. They will crack because of the swaging force.
   / Water Well Connections - Best Methods #3
Amen to not using female plastic to iron adapters. I wound up with a major leak in the middle of January due to using one. Yup, split right on the casting seam.
Harry K
   / Water Well Connections - Best Methods #4
Harry K
I was fortunate to have better hearing 30 years ago and heard the coupling crack after hand tightening down in the trench and 2 short strokes with a pipe wrench. No guarantees with the hearing today.
   / Water Well Connections - Best Methods #5
I have 4 line manifold made from T fittings with independent ball valves for each run.
If I need more will just splice on and continue. PVC is easy to work with.
I assume everyone is using flexible PVC for underground water supply lines?
   / Water Well Connections - Best Methods #7
I recently noticed a plumber using gray fittings when replacing some PVC around a well's tank. He said he only uses schedule 80 fittings, since they are less likely to crack.
   / Water Well Connections - Best Methods #8
1 1/4" sch 40. Got a smokin deal from Lowes on 20' sticks they were trying to get out of their stores... Picked up 78 sticks for <$1.50 ea...
   / Water Well Connections - Best Methods #9
Am I missing something or would you have to cut the PVC to pull the pump?
   / Water Well Connections - Best Methods #10
Looks like maybe the 1st time but a union will fix it going forward....
2009 Hyundai Sonata Sedan (A59231)
2009 Hyundai...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
Hustler super Z zero turn (A56859)
Hustler super Z...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
