cracked bell housing
   / cracked bell housing
Iam still waiting to get my toy back when I do I will make sure the loader bolts are tight and check them frequently. jinman is right the previous owner may have had the bolts loosen causing the crack im glad i found it before the warrenty ran out:eek:
   / cracked bell housing #12
Just a quick comment. I would accept a welded bellhousing for a warranty repair. A rebullt injecctor pump yes (which I did) , but not a welded bellhousing.
Andy
   / cracked bell housing #13
When I was shopping for a compact tractor there was one warning (among many) about front end loaders attached to the bell housing rather than the frame . I was told that the number one enemy of that design was when the driver was unable to force the shovel into the desired load there is sometimes a desire to smash into it in order to get under the load . The shock is quite destructive to the bell housing which seems to be a "weak link". If the bell housing is aluminum the chances of failure increase .
well I finaly got my tractor back with a new bell housing and all looks to be done well the people at wallingford equipment are very good to deal with they genuinely seemed want to make you happy . I have put about 4 hours on It since yesterday its great to have it back.:D
   / cracked bell housing #15
Agreed if it is cast iron. I have heard from many welders who avoid cast iron but most say welding cast steel is reliable. Was it iron or steel?
   / cracked bell housing #16
general J has not posted in over 5 years.
   / cracked bell housing #17
Cast Iron can be welded.
Follow the link to a slide show for a repair we did on a Ford 5000 3 or 4 years ago.
The transmission broke because it had a loader that was improperly mounted and the tractor was abused terribly. The fellow who bought it uses it for all his tillage and to feed large round bales with the 3 point and a bale spear.
We recommended he never put a loader on it which I doubt he will.
If you move your mouse over the pictures you will see descriptions at the top of each photo.
5000 Transmission Repair Slideshow by Ultradog | Photobucket
   / cracked bell housing #18
i have the same problem with tc30 new holland, how much does it cost to remove & replace? mine cracked from front to back i think this was caused by front loader bucket. does anybody know part #
   / cracked bell housing #19
A new case (SBA320111753) TC30 Clutch Housing.PNG is $1600. If you replace the case, you will probably do the clutch at the same time so about $2000 in parts. A New Holland Dealer will probably have about $2500 in labor. It would be cheaper to locate one in a salvage yard and have an independent mechanic do it.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2002 International 9200i Truck (A56438)
2002 International...
